Hi all,
I have Home assistant running in a VM on proxmox and Frigate running in an LXC which runs a docker container. I understand this would all be totally unsupported as it’s a difficult to trouble shoot.
Frigate is running really well (gpu passthrough, low inference, low cpu usage, etc) and i have no issues with it using it’s own interface direct and have fulfilled all of the requirements to run it with home assistant.
On the home assistant install i have installed Mosquito for mqtt as specified in the frigate docs.
On home assistant i installed the integration (via HACS i think as it’s not official)
On Home Assistant i have installed the associated card and added it to my dashboard and get the feed and it operates as it should.
This is then where it all goes wrong. The Dashboard becomes unresponsive you can click on items in the side menu but you just get the loading circle and no response. This happens randomly but pretty consistently including while trying to make edits to the dashboard. The only way to recover is kill the browser tab and reload. If you remove the card the Dashboard stops crashing.
MQTT server Log extract
2024-05-29 19:29:29: New connection from 172.30.32.2:42524 on port 1883.
2024-05-29 19:29:29: Client <unknown> closed its connection.
2024-05-29 19:31:29: New connection from 172.30.32.2:48400 on port 1883.
2024-05-29 19:31:29: Client <unknown> closed its connection.
2024-05-29 19:32:29: Saving in-memory database to /data//mosquitto.db.
2024-05-29 19:33:29: New connection from 172.30.32.2:42966 on port 1883.
2024-05-29 19:33:29: Client <unknown> closed its connection.
Home Assistant Core Log
Log Details (ERROR)
Logger: homeassistant.components.stream.stream.camera.rearcam
Source: components/stream/__init__.py:448
integration: Stream (documentation, issues)
First occurred: 17:25:21 (7 occurrences)
Last logged: 19:33:51
Error from stream worker: Error opening stream (ERRORTYPE_111, Connection refused) rtsp://192.168.2.35:8554/RearCam
Frigate log
2024-05-29 19:40:02.632068151 192.168.2.201 - - [29/May/2024:19:40:02 +0100] "GET /api/events?cameras=FrontCam&limit=50&include_thumbnails=0 HTTP/1.1" 200 24573 "-" "HomeAssistant/2024.5.4 aiohttp/3.9.5 Python/3.12" "-"
2024-05-29 19:40:02.654116384 192.168.2.201 - - [29/May/2024:19:40:02 +0100] "GET /api/events?cameras=RearCam&limit=50&include_thumbnails=0 HTTP/1.1" 200 24317 "-" "HomeAssistant/2024.5.4 aiohttp/3.9.5 Python/3.12" "-"
2024-05-29 19:40:02.669137729 192.168.2.201 - - [29/May/2024:19:40:02 +0100] "GET /api/events?cameras=SideCam&limit=50&include_thumbnails=0 HTTP/1.1" 200 7420 "-" "HomeAssistant/2024.5.4 aiohttp/3.9.5 Python/3.12" "-"
2024-05-29 19:40:02.729120220 192.168.2.201 - - [29/May/2024:19:40:02 +0100] "GET /api/FrontCam/latest.jpg HTTP/1.1" 200 54371 "-" "HomeAssistant/2024.5.4 aiohttp/3.9.5 Python/3.12" "-"
2024-05-29 19:40:02.736927653 192.168.2.201 - - [29/May/2024:19:40:02 +0100] "GET /api/RearCam/latest.jpg HTTP/1.1" 200 66947 "-" "HomeAssistant/2024.5.4 aiohttp/3.9.5 Python/3.12" "-"
2024-05-29 19:40:02.740740609 192.168.2.201 - - [29/May/2024:19:40:02 +0100] "GET /api/SideCam/latest.jpg HTTP/1.1" 200 79805 "-" "HomeAssistant/2024.5.4 aiohttp/3.9.5 Python/3.12" "-"
2024-05-29 19:40:31.574680044 [2024-05-29 19:40:31] frigate.comms.mqtt ERROR : Unable to publish to SideCam/motion: client is not connected
2024-05-29 19:40:43.261578211 [2024-05-29 19:40:43] frigate.comms.mqtt ERROR : Unable to publish to FrontCam/motion: client is not connected
2024-05-29 19:40:52.446451508 [2024-05-29 19:40:52] frigate.comms.mqtt ERROR : Unable to publish to stats: client is not connected
2024-05-29 19:41:52.506257289 192.168.2.153 - - [29/May/2024:19:41:52 +0100] "GET /ws HTTP/1.1" 101 44704 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36" "-"
2024-05-29 19:41:53.015930929 [2024-05-29 19:41:53] frigate.comms.mqtt ERROR : Unable to publish to stats: client is not connected
2024-05-29 19:42:00.305413908 [2024-05-29 19:42:00] frigate.comms.mqtt ERROR : Unable to publish to FrontCam/motion: client is not connected
2024-05-29 19:42:34.443726629 [2024-05-29 19:42:34] frigate.comms.mqtt ERROR : Unable to publish to RearCam/motion: client is not connected
2024-05-29 19:42:53.579073220 [2024-05-29 19:42:53] frigate.comms.mqtt ERROR : Unable to publish to stats: client is not connected
2024-05-29 19:43:04.519969096 [2024-05-29 19:43:04] frigate.comms.mqtt ERROR : Unable to publish to RearCam/motion: client is not connected
2024-05-29 19:43:54.148116765 [2024-05-29 19:43:54] frigate.comms.mqtt ERROR : Unable to publish to stats: client is not connected
2024-05-29 19:44:54.148393402 192.168.2.153 - - [29/May/2024:19:44:54 +0100] "GET /ws HTTP/1.1" 101 22280 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36" "-"
2024-05-29 19:44:54.798716805 [2024-05-29 19:44:54] frigate.comms.mqtt ERROR : Unable to publish to stats: client is not connected
It looks to me as if Home assistant loses the feed from frigate which for some reason makes the dashboard none responsive. How home assistant/Frigate works under the hood is a little beyond me. It feels like a config problem but not where to start.
Any ideas?
