I have a Frigate Card running with the camera stream of my Reolink Doorbell including 2-way-audio in Home Assistant.
I want to unmute only if the doorbell is pressed. The signal for the button-press is available. The challenge is to connect it to the unmute option of the Frigate card to the button press of the doorbell.
I can unmute manually by pressing a button in the frigate card, that works fine
Hi Fabio,
just tested it out. It works the way it is described in the PR.
It is not quite what I am looking for. I wanted to unmute the cameras based on a entity that is available in home assistant. Pressing the button on the will trigger “binary_sensor.reolink_video_doorbell_wifi_visitor” and this is suppose to trigger the unmute button.
