I have only recently installed and configured Frigate and since the outset, I seem to be having a memory leak. After the add-on is started it will creep up until HA becomes unresponsive. I’m guessing the Supervisor then restarts HA after which everything is fine until the memory creeps up again, then rinse and repeat.
I am running HomeAssistantOS in VirtualBox with 1 CPU and 6GB of RAM. When I first installed Frigate it had 4GB RAM but I saw some references to the VM needing more RAM so I increased to 6GB. But this just prolonged the stay of execution.
It seems to definately be Frigate causing this issue as when I stop the add-on the memory returns to normal. I currently have Blue Iris as my NVR with Amazon Rekognition for object recognition but I really want to move this over to Frigate if I can!
I have only added one camera to Frigate so far for testing (but have another four to add):
Need more information to see what is actually using the memory. We have seen this rarely with users using vaapi for hwaccel on certain intel devices but it does not seem you are using hwaccel.
That being said, it looks like your config is somewhat out of date. For example the clips roles does not exist anymore.
Quite right on the out-of-date config, I added the clips based on a blog for configuring it. I have just removed it and restarted the add-on.
Here are the logs since I have just restarted:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2023-02-27 21:26:27] frigate.app INFO : Starting Frigate (0.11.1-2eada21)
[2023-02-27 21:26:27] frigate.app INFO : Creating directory: /tmp/cache
Starting migrations
[2023-02-27 21:26:27] peewee_migrate INFO : Starting migrations
There is nothing to migrate
[2023-02-27 21:26:27] peewee_migrate INFO : There is nothing to migrate
[2023-02-27 21:26:27] frigate.mqtt INFO : Turning on recordings for driveway_cam via mqtt
[2023-02-27 21:26:27] detector.cpu1 INFO : Starting detection process: 210
[2023-02-27 21:26:27] frigate.app INFO : Output process started: 212
[2023-02-27 21:26:27] frigate.app INFO : Camera processor started for driveway_cam: 214
[2023-02-27 21:26:27] ws4py INFO : Using epoll
[2023-02-27 21:26:27] frigate.app INFO : Capture process started for driveway_cam: 217
[2023-02-27 21:26:27] frigate.edgetpu WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
[2023-02-27 21:26:28] ws4py INFO : Using epoll
[2023-02-27 21:26:34] ws4py INFO : Managing websocket [Local => 127.0.0.1:8082 | Remote => 127.0.0.1:35190]
[2023-02-27 21:26:35] ws4py INFO : Terminating websocket [Local => 127.0.0.1:8082 | Remote => 127.0.0.1:35190]
When I have reviewed the logs before the only thing of note I have seen is multiple ‘Manager websocket’ and ‘Terminating websocket’ which I gather is normal behavior. What is interesting is that since the last ‘Terminating websocket’ in the log above the Memory usage has continued to rise even though nothing has been added to the Frigate logs (~2.3GB to ~3.2GB)…
You should use the CLI to run top inside the container. No way to know what is using the memory otherwise.
That, or you could try updating to frigate beta which has a lot more statistical information about cpu and memory usage for each process built into the UI (among many other things, be sure to read the change log first if you update)
I stopped the GA Frigate version just before 08:00 and started the Beta version. I guess whatever was causing the memory leak for me is not present in the Beta version.
I guess I will continue to test with the Beta version but at least initially it seems positive!
