Hi there. First post / Frigate setup here
I am currently running Frigate and using the Advanced Camera Card in Home Assistant, but the remote streaming performance is basically unusable.
For some context, Frigate is running on Proxmox (Optiplex with 11500T), and the camera in is a Reolink PoE Doorbell. To access my home network remotely, I bought a domain and set up a standard Cloudflare tunnel.
The setup works great at home. When I am connected to my home network, the live camera streams load instantly and plays at full framerate (within both the Frigate UI and my HA dashboard). But the moment I disconnect from home and try to access it from the outside (using mobile data through my Cloudflare tunnel), the stream gets incredibly laggy. It instantly drops to roughly 1 FPS and looks like a slow slideshow, or worse. It's choppy and 5ish seconds delayed.
I roughly understand Cloudflare tunnels can sometimes interfere with direct WebRTC connections, so I suspect my setup is failing to negotiate WebRTC and is silently falling back to a slower protocol like MSE or MP4? I am just not entirely sure what I need to change in my configuration to fix the remote pipeline.
Any help would be greatly appreciated!
(my current config)
Frigate:
mqtt:
enabled: true
host: [MQTT_IP]
user: admin
password: [MQTT_PASSWORD]
auth:
enabled: false
go2rtc:
webrtc:
candidates:
- [FRIGATE_LOCAL_IP]:8555
- stun:8555
streams:
doorbell:
- "ffmpeg:http://[CAMERA_IP]/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=admin&password=[CAMERA_PASSWORD]#video=copy#audio=copy#audio=opus"
doorbell_sub:
- "ffmpeg:http://[CAMERA_IP]/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=[CAMERA_PASSWORD]#video=copy#audio=opus"
ffmpeg:
hwaccel_args: preset-vaapi
detectors:
detector01:
type: openvino
device: GPU
model:
width: 300
height: 300
input_tensor: nhwc
input_pixel_format: bgr
path: /openvino-model/ssdlite_mobilenet_v2.xml
labelmap_path: /openvino-model/coco_91cl_bkgr.txt
cameras:
doorbell:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/doorbell_sub
input_args: preset-rtsp-restream
roles:
- detect
roles:
- record
detect:
enabled: true
width: 640
height: 480
fps: 5
record:
enabled: true
continuous:
days: 3
alerts:
retain:
days: 90
mode: motion
detections:
retain:
days: 90
mode: motion
snapshots:
enabled: true
retain:
default: 90
zones:
front_porch:
coordinates:
0.819,0.997,0.617,0.611,0.507,0.61,0.213,0.571,0.197,0.583,0.153,0.574,0.145,0.51,0.002,0.587,0,0.999
loitering_time: 0
friendly_name: Front Porch
inertia: 3
motion:
mask:
0.002,0.587,0.145,0.51,0.153,0.574,0.197,0.583,0.22,0.572,0.507,0.61,0.617,0.611,0.819,0.997,0,0.999
objects:
mask:
0.002,0.587,0.145,0.51,0.153,0.574,0.197,0.583,0.213,0.571,0.507,0.61,0.617,0.611,0.819,0.997,0.999,0.998,1,0,0,0
version: 0.17-0
Advanced Camera Card:
type: custom:advanced-camera-card
view:
default: live
cameras:
- camera_entity: camera.doorbell
live_provider: go2rtc
go2rtc:
stream: doorbell
modes:
- webrtc
- mse
- mp4
live:
preload: true
lazy_load: false
auto_play:
- selected
- visible
menu:
style: outside
buttons:
cameras:
enabled: false
media_player:
enabled: false
timeline:
enabled: true
image:
enabled: false
