Hi there,
i’m trying to set up Frigate in Docker and i’m having a bad time with the record funktion.
I get everything to work if i don’t use the “roles: - record”
config.yml:
mqtt:
host: IP-ADDRESS
user: USER_NAME
password: PASSWORD
detectors:
cpu1:
type: cpu
num_threads: 3
database:
path: /db/frigate.db
ffmpeg:
hwaccel_args: -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format yuv420p
record:
enabled: True
events:
retain:
default: 10
rtmp:
enabled: false
cameras:
flur:
ffmpeg:
inputs:
- path: rtsp://USERNAME:PASSWORD@IP-ADDRESS:554/stream1
roles:
# - detect
- record
detect:
width: 640
height: 360
record:
enabled: True
events:
retain:
default: 10
Log Output:
*** Your config file is not valid! ***
[2023-01-03 11:36:19] frigate.app INFO : Starting Frigate (0.10.1-83481af)
*** Please check the docs at ***
*** https://docs.frigate.video/configuration/index ***
*** Config Validation Errors ***
while scanning for the next token
found character '\t' that cannot start any token
in "<unicode string>", line 33, column 1:
- record
File "/opt/frigate/frigate/app.py", line 312, in start
self.init_config()
File "/opt/frigate/frigate/app.py", line 77, in init_config
user_config = FrigateConfig.parse_file(config_file)
File "/opt/frigate/frigate/config.py", line 900, in parse_file
config = yaml.safe_load(raw_config)
File "/usr/local/lib/python3.8/dist-packages/yaml/__init__.py", line 162, in safe_load
return load(stream, SafeLoader)
File "/usr/local/lib/python3.8/dist-packages/yaml/__init__.py", line 114, in load
return loader.get_single_data()
File "/usr/local/lib/python3.8/dist-packages/yaml/constructor.py", line 49, in get_single_data
node = self.get_single_node()
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 36, in get_single_node
document = self.compose_document()
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 55, in compose_document
node = self.compose_node(None, None)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 84, in compose_node
node = self.compose_mapping_node(anchor)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 133, in compose_mapping_node
item_value = self.compose_node(node, item_key)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 82, in compose_node
node = self.compose_sequence_node(anchor)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 111, in compose_sequence_node
node.value.append(self.compose_node(node, index))
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 64, in compose_node
if self.check_event(AliasEvent):
File "/usr/local/lib/python3.8/dist-packages/yaml/parser.py", line 98, in check_event
self.current_event = self.state()
File "/usr/local/lib/python3.8/dist-packages/yaml/parser.py", line 449, in parse_block_mapping_value
if not self.check_token(KeyToken, ValueToken, BlockEndToken):
File "/usr/local/lib/python3.8/dist-packages/yaml/scanner.py", line 116, in check_token
self.fetch_more_tokens()
File "/usr/local/lib/python3.8/dist-packages/yaml/scanner.py", line 258, in fetch_more_tokens
raise ScannerError("while scanning for the next token", None,
yaml.scanner.ScannerError: while scanning for the next token
- record
*** End Config Validation Errors ***
thanks in advance
