Running HA/Frigate/DP/CF/Double-take on containers ,
Intercom Dahua 2mp - set to H264 720P
Salon Camera - Dahua 4mp H264 1080P
On frigate:
would appriciate good advice improving my config file - especially improving the lag
and remove error ,
second ,Is there an option for live view?
even in debug view - there’s huge delay and video is very slow
after few min i see in frigate logs below errors:
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [swscaler @ 0x55e9e03e4540] [swscaler @ 0x55e9e041d880] deprecated pixel format used, make sure you did set range correctly
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [swscaler @ 0x55e9e0441300] [swscaler @ 0x55e9e03e4540] deprecated pixel format used, make sure you did set range correctly
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [swscaler @ 0x55e9e0441300] [swscaler @ 0x55e9e03f1500] deprecated pixel format used, make sure you did set range correctly
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [swscaler @ 0x55e9e0441300] [swscaler @ 0x55e9e041f540] deprecated pixel format used, make sure you did set range correctly
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 9 expected, 7 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 10 expected, 8 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [h264 @ 0x55e9e0023a80] Increasing reorder buffer to 1
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 11 expected, 9 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 11 expected, 10 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 12 expected, 11 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 14 expected, 12 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 17 expected, 13 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 20 expected, 14 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 21 expected, 15 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 21 expected, 16 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 24 expected, 17 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : More than 1000 frames duplicated
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 31 expected, 18 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 32 expected, 19 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [h264 @ 0x55e9dff80940] Increasing reorder buffer to 10
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 32 expected, 20 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 33 expected, 21 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [rtsp @ 0x55e9dff6abc0] CSeq 35 expected, 22 received.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [flv @ 0x55e9dff82fc0] Failed to update header with correct duration.
[2022-11-22 11:54:52] ffmpeg.intercom.detect ERROR : [flv @ 0x55e9dff82fc0] Failed to update header with correct filesize.
[2022-11-22 12:03:18] frigate.video ERROR : intercom: Unable to read frames from ffmpeg process.
frigate.yaml
mqtt:
host: 192.168.1.113
port: 1883
cameras:
intercom:
mqtt:
timestamp: False
bounding_box: False
crop: True
ffmpeg:
inputs:
- path: rtsp://yyyyy:[email protected]:554/cam/realmonitor?channel=1&subtype=0
roles:
- detect
- rtmp
detect:
height: 720
width: 1280
fps: 5
zones:
zone_intercom:
coordinates: 521,40,1170,49,1158,720,525,720
snapshots:
enabled: True
timestamp: True
retain:
# Required: Default retention days (default: shown below)
default: 3
salon2:
mqtt:
timestamp: False
bounding_box: False
crop: True
# quality: 100
# height: 500
ffmpeg:
inputs:
- path: rtsp://yyyy:[email protected]/cam/realmonitor?channel=1&subtype=0
roles:
- detect
detect:
height: 720
width: 1280
fps: 5
zones:
zone_salon2:
coordinates: 0,84,1130,85,1158,720,0,720
snapshots:
# Optional: Enable writing jpg snapshot to /media/frigate/clips (default: shown below)
# This value can be set via MQTT and will be updated in startup based on retained value
enabled: True
timestamp: True
retain:
default: 3
