a few days ago i installed Home Assistant OS with frigate on a RasPi 4B 4GB. Everything works great but the Coral USB TPU could not be detected. Here is what i‘ve tried:
reboot
changing the usb-port
There is no other device connected to the raspi, the white led on the TPU is on.
I use the same system in my house allready. Here everything works fine.
We always recommend using a powered USB hub as the coral is very picky about power.
In any case, which addon are you using? Some users have found that they need to run the full access addon with protection mode disabled for the coral to get picked up.
I’m jumping in the discussion because I have same problem. I’ve got an USB Coral edgetpu. I used to use it on HA on a NUC, but it went down and I had to replace it.
I now try to reinstall Frigate and coral on a NUC11ATKC2.
I run HA Core 2022.10.5 and OS version 9.2
I tried to load the last backup I made from preceding NUC (frigate and coral were perfectly operationnals). I can’t get Frigate detect Coral on USB.
I tried different USB ports, with or without a powered USB hub, with different USB cables… Nothing works.
I wonder if there would be a hardware failure in the Coral. Do you know how I could sort it out ?
I tried to use Coral USB Accelerator in HA for Frigate (installed in HA as add-on) but it’s not detected by HA/Frigate (see log file bellow). The latest version of HA is installed in Virtualbox 7.0 on Mini PC (Intel Celeron N5100, Ubuntu 23.04). I also added in configration file of Frigate the following:
detectors:
coral:
type: edgetpu
device: usb
Any idea what I’m doing wrong here?
2023-08-12 13:29:30.041231439 Process detector:coral:
2023-08-12 13:29:30.043694778 [2023-08-12 15:29:30] frigate.detectors.plugins.edgetpu_tfl ERROR : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2023-08-12 13:29:30.045000356 [2023-08-12 15:29:30] frigate.app INFO : Camera processor started for camzunaj: 307
2023-08-12 13:29:30.050800853 Traceback (most recent call last):
2023-08-12 13:29:30.050850595 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2023-08-12 13:29:30.050852218 delegate = Delegate(library, options)
2023-08-12 13:29:30.050853671 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2023-08-12 13:29:30.050859027 raise ValueError(capture.message)
2023-08-12 13:29:30.050860497 ValueError
2023-08-12 13:29:30.050874935
2023-08-12 13:29:30.050876366 During handling of the above exception, another exception occurred:
2023-08-12 13:29:30.050877273
2023-08-12 13:29:30.050878358 Traceback (most recent call last):
2023-08-12 13:29:30.050948803 File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2023-08-12 13:29:30.050950345 self.run()
2023-08-12 13:29:30.050951662 File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2023-08-12 13:29:30.050952817 self._target(*self._args, **self._kwargs)
2023-08-12 13:29:30.050954114 File "/opt/frigate/frigate/object_detection.py", line 98, in run_detector
2023-08-12 13:29:30.050955418 object_detector = LocalObjectDetector(detector_config=detector_config)
2023-08-12 13:29:30.051019488 File "/opt/frigate/frigate/object_detection.py", line 52, in __init__
2023-08-12 13:29:30.051021493 self.detect_api = create_detector(detector_config)
2023-08-12 13:29:30.051022745 File "/opt/frigate/frigate/detectors/__init__.py", line 24, in create_detector
2023-08-12 13:29:30.051023832 return api(detector_config)
2023-08-12 13:29:30.051025132 File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 37, in __init__
2023-08-12 13:29:30.051026445 edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2023-08-12 13:29:30.051040431 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2023-08-12 13:29:30.051041859 raise ValueError('Failed to load delegate from {}\n{}'.format(
2023-08-12 13:29:30.051077776 ValueError: Failed to load delegate from libedgetpu.so.1.0
