nuki47
(Nuki47)
February 7, 2024, 9:27am
1
How are these errors to be understood? Had recently just changed the retain value in the frigate.yaml…
024-02-07 06:27:37.573309466 [INFO] Starting go2rtc healthcheck service...
2024-02-07 06:27:41.234813826 2024/02/07 07:27:41 [error] 148#148: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "xxxxx-frigate:5000"
2024-02-07 06:27:42.380612798 2024/02/07 07:27:42 [error] 149#149: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", upstream: "http://127.0.0.1:5001version", host: "127.0.0.1:5000"
nuki47
(Nuki47)
February 10, 2024, 7:28pm
2
solved: record → retain has no attribute “default”
othalbadr
(OTHMAN)
February 14, 2024, 3:41am
3
I am facing the same problem… Can you explain more?
nuki47
(Nuki47)
February 14, 2024, 6:38pm
4
Please check this code…in the section record is no default value:
The problem remains…
My configuration is this:
record:
enabled: True
retain:
days: 0
mode: all
events:
retain:
default: 7
mode: active_objects
vajdum
August 3, 2024, 2:17pm
6
In my case the problem was an urlencoded character in the camera password.
With the old frigate the PW must be urlencoded to work (characters like %$#)
With frigate 0.13.2 it is NOT allowed to be encoded.
For setting up go2rtc it MUST be encoded to work.
