Frigate - Finally got GPU working, now can't get mmpeg to work without errors
For some good time now, I have had homeassistant running in proxmox on a VM. I had toyed with getting GPU acceleration working but always hit a dead end in one way or another. Finally had some downtime to mess with it and I think I made some progress, after messing with some proxmox settings and frigate settings I finally see “Intel GPU” at the bottom of the frigate screen. Unfortunately all my cameras come up “No frames have been received, check error logs”. If I go into the logs, I see from the start errors such as inside_deck: unable to read frames from ffmpeg process followed by a inside_deck: ffmpeg proccess is not running exiting captujre thread. I searched a bunch for an answer and came up with nothing, so I assume I’m doing something dumb in my config. I’m pulling my hair out at this point. Below is my config file. Thanks!
database:
  path: /config/frigate.db
ffmpeg:
   hwaccel_args: preset-vaapi
detectors:
  coral:
    type: edgetpu
    device: usb
live:
  height: 720
  quality: 8
mqtt:
  host: 192.168.1.18
  port: 1883
  topic_prefix: frigate
  client_id: frigate
  user: mqtt
  password: password
  stats_interval: 60
go2rtc:
  streams:
    front_study:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
    front_door:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0#backchannel=0
    front_garage:
      - rtsp://admin:[email protected]:554/h264Preview_01_main
    side_deck:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1
    basement_door:
    inside_deck:
detect:
  # Optional: width of the frame for the input with the detect role (default: shown below)
  width: 1280
  # Optional: height of the frame for the input with the detect role (default: shown below)
  height: 720
  # Optional: desired fps for your camera for the input with the detect role (default: shown below)
  # NOTE: Recommended value of 5. Ideally, try and reduce your FPS on the camera.
  fps: 5
  # Optional: enables detection for the camera (default: True)
  # This value can be set via MQTT and will be updated in startup based on retained value
  enabled: true
  # Optional: Number of frames without a detection before frigate considers an object to be gone. (default: 5x the frame rate)
  max_disappeared: 25
  stationary:
    interval: 50
    threshold: 50
objects:
  # Optional: list of objects to track from labelmap.txt (default: shown below)
  track:
    - person
    - face
    - license_plate
    - dog
    - cat
    - car
    - amazon
    - fedex
    - ups
    - package
birdseye:
#  # Optional: Enable birdseye view (default: shown below)
  enabled: true
#  # Optional: Width of the output resolution (default: shown below)
  width: 1920
#  # Optional: Height of the output resolution (default: shown below)
  height: 1080
#  # Optional: Encoding quality of the mpeg1 feed (default: shown below)
#  # 1 is the highest quality, and 31 is the lowest. Lower quality feeds utilize less CPU resources.
  quality: 8
#  # Optional: Mode of the view. Available options are: objects, motion, and continuous
#  #   objects - cameras are included if they have had a tracked object within the last 30 seconds
#  #   motion - cameras are included if motion was detected in the last 30 seconds
#  #   continuous - all cameras are included always
  mode: continuous
timestamp_style:
  # Optional: Position of the timestamp (default: shown below)
  #           "tl" (top left), "tr" (top right), "bl" (bottom left), "br" (bottom right)
  position: tl
  # Optional: Format specifier conform to the Python package "datetime" (default: shown below)
  #           Additional Examples:
  #             german: "%d.%m.%Y %H:%M:%S"
  format: '%m/%d/%Y %H:%M:%S'
  # Optional: Color of font
record:
  # Optional: Enable recording (default: shown below)
  enabled: true
  # Optional: Number of days to retain recordings regardless of events (default: shown below)
  # NOTE: This should be set to 0 and retention should be defined in events section below
  #       if you only want to retain recordings of events.
 # retain_days: 0
  # Optional: Event recording settings
  events:
    # Optional: Maximum length of time to retain video during long events. (default: shown below)
    # NOTE: If an object is being tracked for longer than this amount of time, the retained recordings
    #       will be the last x seconds of the event unless retain_days under record is > 0.
    # Optional: Number of seconds before the event to include (default: shown below)
    pre_capture: 5
    # Optional: Number of seconds after the event to include (default: shown below)
    post_capture: 5
    # Optional: Objects to save recordings for. (default: all tracked objects)
    objects:
      - person
      - car
    # Optional: Restrict recordings to objects that entered any of the listed zones (default: no required zones)
    # Optional: Retention settings for recordings of events
    retain:
      # Required: Default retention days (default: shown below)
      mode: active_objects
      default: 7
      # Optional: Per object retention days
      objects:
        person: 14
        car: 7
cameras:
  front_door:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/front_door
          roles:
            - detect
            - rtmp
            - record
    detect:
      width: 1920
      height: 1080
      fps: 5
    objects:
      track:
        - cat
        - dog
        - person
        - car
      filters:
        car: {}
      mask: 0.283,0.559,0.943,0.555,0.949,0.491,0.909,0,0.35,0,0.301,0.285,0.287,0.574
    motion:
      mask: >-
        0.304,0,0.921,0,0.962,0.561,0.278,0.567
    zones:
      Front_Door:
        coordinates: 0.318,1,1,1,0.954,0.561,0.288,0.566
        inertia: 7
        loitering_time: 0
        objects:
          - cat
          - person
          - dog
          - car
      Street_and_neighbors:
        coordinates: 0.306,0,0.289,0.552,0.994,0.553,0.997,0.006
        loitering_time: 0
    review:
      alerts:
        required_zones: Front_Door
      detections:
  front_study:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/front_study
          roles:
            - detect
            - rtmp
            - record
    detect:
      width: 1920
      height: 1080
      fps: 5
    objects:
      track:
        - bicycle
        - cat
        - dog
        - car
        - person
      filters:
        car: {}
      mask: 0.055,0.132,0.041,0.407,0.111,0.378,0.28,0.383,0.489,0.417,0.999,0.542,1,0.187
    motion:
      mask: >-
        1,0.589,1,0.232,0.4,0.219,0.3,0.212,0.05,0.165,0.024,0.505,0.374,0.516
    zones:
      Front_yard:
        coordinates: 0.121,0.98,0.977,0.936,0.975,0.546,0.469,0.433,0.066,0.574
        objects:
          - person
          - dog
          - cat
        inertia: 3
        loitering_time: 0
      Driveway:
        coordinates:
          0.113,0.382,0.165,0.389,0.282,0.389,0.381,0.398,0.484,0.42,0.361,0.445,0.045,0.563,0.04,0.421
        inertia: 7
        loitering_time: 0
        objects:
          - car
          - person
          - bicycle
          - dog
          - cat
      Street:
        coordinates: 0.196,0.388,0.202,0.193,0.307,0.212,0.998,0.23,1,0.518,0.527,0.413,0.359,0.391
        loitering_time: 0
    review:
      alerts:
        required_zones:
          - Driveway
          - Front_yard
      detections:
        required_zones:
          - Driveway
          - Front_yard
  front_garage:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/front_garage
          roles:
            - detect
            - rtmp
            - record
    detect:
      width: 1920
      height: 1080
     # width: 2560
     # height: 1920
      fps: 5
    objects:
      track:
        - bicycle
        - cat
        - dog
        - car
        - person
    #  filters:
      filters:
        bicycle: {}
        car: {}
      mask: 0.706,0.343,0.474,0.401,0.397,0.459,0,0.603,0,0,0.868,0,0.895,0.337,0.611,0.365
    motion: {}
    zones:
      Driveway2:
        coordinates: 0.92,1,0.945,0.429,0.318,0.453,0.179,0.506,0,0.587,0,1
        inertia: 7
        loitering_time: 0
        coordinates: 0.002,0.581,0.318,0.444,0.621,0.354,0.887,0.325,0.853,0,0.002,0.005
        loitering_time: 0
    review:
      alerts:
        required_zones: Driveway2
      detections:
  side_deck:
    ffmpeg:
      inputs:
        - path: >-
            rtsp://127.0.0.1:8554/side_deck
          roles:
            - detect
            - rtmp
            #- record
    detect:
      width: 640
      height: 480
      fps: 5
    objects:
      track:
        - person
        - cat
    zones:
      Deck_side_of_House:
        coordinates:
          0.17,0.96,0.213,0.734,0.307,0.452,0.25,0.406,0.22,0.33,0.303,0.191,0.431,0.088,0.683,0.086,0.724,0.098,0.671,0.998
        loitering_time: 0
        inertia: 3
    review:
      alerts:
        required_zones: Deck_side_of_House
  Basement_door:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/basement_door
          roles:
            - detect
            - rtmp
           # - record
    detect:
      width: 1920
      height: 1080
     # width: 2692
     # height: 1944
      fps: 5
    objects:
      track:
        - cat
        - bird
        - dog
        - person
      filters:
        person: {}
        bird:
          mask:
            0.002,0.995,0.002,0.303,0.092,0.253,0.228,0.243,0.239,0.324,0.341,0.324,0.334,0.207,0.619,0.278,0.811,0.327,0.91,0.318,0.904,0.459,0.931,0.478,0.998,0.379,0.998,0.995
    zones:
      Side_Deck:
        coordinates: 0,0.302,0.088,0.25,0.081,0.123,0.018,0.089,0.002,0.108
        loitering_time: 0
        objects: person
        inertia: 3
      Under_Deck:
        coordinates:
          0.088,0.253,0,0.309,0,1,1,1,1,0.375,0.935,0.481,0.899,0.46,0.911,0.315,0.805,0.324,0.326,0.206,0.339,0.323,0.234,0.317,0.226,0.24
        loitering_time: 0
        objects: person
        inertia: 3
    review:
      alerts:
        required_zones:
          - Side_Deck
          - Under_Deck
    motion:
      threshold: 52
      contour_area: 55
      improve_contrast: 'true'
  inside_deck:
    ffmpeg:
      inputs:
        - path: >-
            rtsp://127.0.0.1:8554/inside_deck
          roles:
            - detect
            - rtmp
            #- record
    detect:
      width: 1920
      height: 1080
      fps: 5
    objects:
      track:
        - person
        - cat
    zones:
      Deck_Inside:
        coordinates: 0.028,0.372,0.243,0.999,0.722,0.989,0.915,0.289,0.951,0,0.001,0.004
        loitering_time: 2
        inertia: 3
    review:
      alerts:
        required_zones: Deck_Inside
version: 0.14
camera_groups:
  Front_House:
    order: 1
    icon: LuDoorClosed
    cameras:
      - front_study
      - front_garage
      - front_door
  Back_and_side_of_house:
    order: 2
    icon: LuTreePine
    cameras:
      - inside_deck
      - side_deck
      - Basement_door
need to see the logs
