Frigate generating "database disk image is malformed" errors
Hi everyone.
I have Frigate set up for 2 cameras:
  • Amcrest AD410
  • Dahua wired turret camera (DH-IPC-HDW3466EMP-S-AUS-BLK)
My frigate config is below. I have two streams for each camera - one high res for recordings, one lower res for detection. I’ve configured it using go2rtc and have a third camera which uses one of the high res feeds for object detection, with most of the feed masked against motion (there is a particular part of the feed I want to detect people in but in the low res feed people aren’t clear enough).
All has been working fine, but a couple of days ago I can no longer view clips for two of the cameras - front_gate and driveway_camera. The garden_gate_camera is working fine (this is the one which uses the high res feed for object detction).
I upgraded to Frigate 0.13.1 the other day - I’m not sure if this is the point at which the clips stoppped working.
The Frigate logs show “database disk image is malformed”. I tried to fix this by:
  • Stopping the Frigate addon
  • Moving /config/frigate.db to a back-up folder
  • Restarting the Frigate addon
The addon recreated the database but the problem has persisted - only clips from garden_gate_camera are working.
Accessing Home Assistant using samba share, I’m able to open the video files in VLC so the files themselves are fine, the problem seems to be with Frigate accessing its database to piece the videos back together.
Does anyone have any ideas how I can fix this?
Error log
2024-02-14 09:39:31.054114840  Traceback (most recent call last):
2024-02-14 09:39:31.054117044    File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2190, in wsgi_app
2024-02-14 09:39:31.054118692      response = self.full_dispatch_request()
2024-02-14 09:39:31.054121081    File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1486, in full_dispatch_request
2024-02-14 09:39:31.054122673      rv = self.handle_user_exception(e)
2024-02-14 09:39:31.054125081    File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1484, in full_dispatch_request
2024-02-14 09:39:31.054126562      rv = self.dispatch_request()
2024-02-14 09:39:31.054128951    File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1469, in dispatch_request
2024-02-14 09:39:31.054131062      return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
2024-02-14 09:39:31.054132951    File "/opt/frigate/frigate/http.py", line 1897, in vod_event
2024-02-14 09:39:31.054134914      vod_response = vod_ts(event.camera, event.start_time, end_ts)
2024-02-14 09:39:31.054136766    File "/opt/frigate/frigate/http.py", line 1785, in vod_ts
2024-02-14 09:39:31.054138914      Recordings.select(Recordings.path, Recordings.duration, Recordings.end_time)
2024-02-14 09:39:31.054141080    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 2049, in iterator
2024-02-14 09:39:31.054142802      return iter(self.execute(database).iterator())
2024-02-14 09:39:31.054144914    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 1972, in inner
2024-02-14 09:39:31.054146654      return method(self, database, *args, **kwargs)
2024-02-14 09:39:31.054148802    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 2043, in execute
2024-02-14 09:39:31.054150284      return self._execute(database)
2024-02-14 09:39:31.054152450    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 2216, in _execute
2024-02-14 09:39:31.054153969      cursor = database.execute(self)
2024-02-14 09:39:31.054156117    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 3260, in execute
2024-02-14 09:39:31.054157691      return self.execute_sql(sql, params)
2024-02-14 09:39:31.054160061    File "/usr/local/lib/python3.9/dist-packages/playhouse/sqliteq.py", line 247, in execute_sql
2024-02-14 09:39:31.054161598      return self._execute(sql, params)
2024-02-14 09:39:31.054163802    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 3252, in execute_sql
2024-02-14 09:39:31.054165339      cursor.execute(sql, params or ())
2024-02-14 09:39:31.054167506    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 3020, in __exit__
2024-02-14 09:39:31.054169413      reraise(new_type, new_type(exc_value, *exc_args), traceback)
2024-02-14 09:39:31.054171561    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 192, in reraise
2024-02-14 09:39:31.054173043      raise value.with_traceback(tb)
2024-02-14 09:39:31.054175246    File "/usr/local/lib/python3.9/dist-packages/peewee.py", line 3252, in execute_sql
2024-02-14 09:39:31.054176783      cursor.execute(sql, params or ())
2024-02-14 09:39:31.054178561  peewee.DatabaseError: database disk image is malformed
Frigate config file
mqtt:
  host: 192.168.1.44
  user: mqttuser
  password: xxxxxxxxxxxxx
detectors:
  coral:
    type: edgetpu
    device: usb
birdseye:
  enabled: false
ffmpeg:
  hwaccel_args: preset-rpi-64-h264
go2rtc:
  streams:
    front_gate:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0&unicast=true
    front_gate_sub:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1&unicast=true
    driveway_camera:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
    driveway_camera_sub:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=2&unicast=true&proto=Onvif
cameras:
  front_gate:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/front_gate
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/front_gate_sub
          roles:
            - detect
    detect:
      width: 720
      height: 576
      fps: 4
      enabled: true
    objects:
      track:
        - person
        - car
        - bicycle
      filters:
        car:
          mask: 132,303,132,276,0,295,0,329
    snapshots:
      enabled: true
      timestamp: true
      bounding_box: true
      retain:
        default: 178
      required_zones:
        - front_driveway
        - neighbours_driveway
    record:
      enabled: true
      retain:
        days: 7
        mode: motion
      events:
        pre_capture: 10
        post_capture: 10
        retain:
          default: 28
          mode: active_objects
        required_zones:
          - front_driveway
    motion:
      mask:
        - 0,329,0,0,720,0,720,246,120,254,108,308
    zones:
      front_driveway:
        coordinates: 0,393,248,436,253,229,720,256,720,576,0,576
      neighbours_driveway:
        coordinates: 244,233,161,248,148,366,21,399,252,429
      front_driveway_left:
        coordinates: 246,576,0,576,0,393,253,434
      front_driveway_centre:
        coordinates: 509,576,493,229,250,229,245,576
      front_driveway_right:
        coordinates: 720,576,720,258,510,233,509,576
  driveway_camera:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/driveway_camera
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/driveway_camera_sub
          roles:
            - detect
    detect:
      width: 1280
      height: 720
      fps: 4
      enabled: true
    objects:
      track:
        - person
        - car
        - dog
      filters:
        car:
          mask:
            - 1280,720,0,720,0,0,220,0,246,489,665,475,734,0,1280,0
        person:
          threshold: 0.6
          mask:
            - 672,207,683,272,604,272,605,209
    snapshots:
      enabled: true
      timestamp: true
      bounding_box: true
      retain:
        default: 178
    record:
      enabled: true
      retain:
        days: 14
        mode: motion
      events:
        pre_capture: 10
        post_capture: 10
        retain:
          default: 28
    motion:
      mask:
        - 0,0,1280,0,1280,720,320,720,477,456,970,462,1074,76,404,49,325,49,294,231,259,344,294,486,226,485,99,720,0,720
      contour_area: 20
    zones:
      garden_gate:
        coordinates: 419,154,379,159,383,58,421,55
      front_door:
        coordinates: 978,478,728,417,785,0,1076,0
  garden_gate_camera:
    ffmpeg:
      inputs:
          roles:
            - record
          roles:
            - detect
    detect:
      width: 2688
      height: 1520
      fps: 4
      enabled: true
    objects:
      track:
        - person
    snapshots:
      enabled: true
      timestamp: true
      bounding_box: true
      retain:
        default: 178
    record:
      enabled: true
      retain:
        days: 0
      events:
        pre_capture: 10
        post_capture: 10
        retain:
          default: 28
    motion:
      mask:
        - 754,0,0,0,0,1520,2688,1520,2688,0,752,0,752,103,896,113,900,324,762,334
      contour_area: 20
I havent frigate addon but i realize driveway_camera path same as garden_gate_camera. Is it normal ?
Maybe a little unusual but I think it should be ok. The high res feed is too demanding for the CPU but I’ve used a motion mask to target a small section of that feed in garden_gate_camera so I can detect people in a section if the video which is quite far away and needs higher resolution. This set up was working for a week before the errors started so I think it should be fine.
For now I have uninstalled the add-on and Frigate integration, deleted all media, config and DB files, rebooted Home Assistant and reinstalled the addon.
Seems to be working ok for now so I’ll monitor and see what happens over the next few days.
Today the problem has returned. The only camera I can view recordings is the garden gate camera.
Hoping someone might have some ideas to resolve this?
