I’ve succesfully added my first camera “Voordeur3” in my Frigate configuration.
I’m trying to add a second camera “Living”, which apparently uses H265 instead of H264.
I’ve added the camera the same way in the configuration as my first one, but it appears as a green screen.
I’m able to run the stream correctly from my VLC player.
I used the pixel settings (in Frigate) I could see in codec part of Mediaplayer.
HA is installed on :
Intel Celeron Dualcore NUC 8GB RAM en 120GB SSD - J4025 2GHz - WIFI/Bluetooth - 2x HDMI - Win11 PRO
HA is running in HyperV on the box.
I’ve got the following in my log files :
[2023-03-09 12:52:30] frigate.video ERROR : Living: Unable to read frames from ffmpeg process.
[2023-03-09 12:52:30] frigate.video ERROR : Living: ffmpeg process is not running. exiting capture thread...
[2023-03-09 12:52:31] frigate.record WARNING : Discarding a corrupt recording segment: Voordeur3-20230309125222.mp4
[2023-03-09 12:52:40] watchdog.Living ERROR : Ffmpeg process crashed unexpectedly for Living.
[2023-03-09 12:52:40] watchdog.Living ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : [rtsp @ 0x55e8f87b9e40] Illegal combination of S and E bit in RTP/HEVC packet
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 2 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : [hevc @ 0x55e8f87bedc0] PPS id out of range: 0
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 1 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : [hevc @ 0x55e8f87bedc0] Error parsing NAL unit #0.
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 26 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 17 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 6 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 40 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 46 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 44 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Last message repeated 18 times
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : [rtsp @ 0x55e8f87b9e40] Could not find codec parameters for stream 0 (Video: hevc, none, 1280x720): unspecified pixel format
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Could not write header for output file #0 (incorrect codec parameters ?): Immediate exit requested
[2023-03-09 12:52:40] ffmpeg.Living.detect ERROR : Error initializing output stream 0:0 --
[2023-03-09 12:53:00] watchdog.Living INFO : No frames received from Living in 20 seconds. Exiting ffmpeg...
[2023-03-09 12:53:00] watchdog.Living INFO : Waiting for ffmpeg to exit gracefully...
[2023-03-09 12:53:00] frigate.video ERROR : Living: Unable to read frames from ffmpeg process.
[2023-03-09 12:53:00] frigate.video ERROR : Living: ffmpeg process is not running. exiting capture thread...
[2023-03-09 12:53:01] frigate.record WARNING : Discarding a corrupt recording segment: Voordeur3-20230309125252.mp4
My Frigate.yaml
mqtt:
host: 192.168.1.101
port: 1883
user: Mosquitto
password: xahz9uv17257575g1aetiaLoo3dahnge6quaagh0ieZae
#ffmpeg:
# hwaccel_args:
# - -hwaccel
# - -hwaccel_device
# - /dev/dri/renderD128
# - -hwaccel_output_format yuv420p
#ffmpeg:
# hwaccel_args: -c:v h264_qsv
cameras:
Voordeur3:
ffmpeg:
inputs:
- path: rtsp://admin:@192.168.1.10:8001
roles:
- rtmp
- detect
- record
rtmp:
enabled: True
detect:
width: 1920
height: 1080
fps: 5
record:
enabled: True
retain:
days: 0
mode: active_objects
events:
pre_capture: 10
post_capture: 10
objects:
- person
- dog
- cat
retain:
default: 3
snapshots:
enabled: True
timestamp: True
retain:
default: 10
objects:
person: 15
Living:
ffmpeg:
inputs:
- path: rtsp://admin:@192.168.1.20:8001
roles:
- detect
- record
rtmp:
enabled: False
detect:
width: 2304
height: 1296
fps: 5
record:
enabled: True
retain:
days: 0
events:
pre_capture: 10
post_capture: 10
objects:
- person
- dog
- cat
retain:
default: 3
snapshots:
enabled: True
timestamp: True
retain:
default: 10
objects:
person: 15
# objects: 3
#events:
# retain:
# default: 3
# mode: active_objects
# objects:
# dog: 1
# car: 2
# person: 5
birdseye:
enabled: False
