I’d like to show the Frigate Birdseye cam into HADashboard there is a way to do this?
Thanks.
Thanks.
Yes, GitHub - dermotduffy/frigate-hass-card: A Lovelace card for Frigate in Home Assistant supports this
Hi @crzynik,
I have the necessity to add into HADashboard (Appdaemon addon) the frigate cards work on Home Assistant web page.
Into HADashboard i can add an entity camera but there isn’t the Birdseye at system i think the custom card read directly the data from the frigate instance.
Does anyone have a code example of this? I’ve tried following that yaml but it leaves the Lovelace card spinning forever. I’ve had to delete the dashboard and start again!
Sure, this is what mine looks like
type: custom:frigate-card
view:
default: live
camera_select: live
menu:
buttons:
frigate:
enabled: false
snapshots:
enabled: false
image:
enabled: false
timeline:
enabled: false
frigate_ui:
enabled: false
style: outside
position: bottom
live:
preload: true
controls:
thumbnails:
mode: none
next_previous:
style: none
title:
mode: none
lazy_load: true
draggable: true
lazy_unload: all
cameras:
- live_provider: frigate-jsmpeg
frigate:
camera_name: birdseye
dependencies:
all_cameras: true
Thanks you, seems I was missing the dependencies piece.
I copied exact and still get the spinning piece. I am not on version 12 of Frigate and not sure if something changed. Birdseye in frigate itself if fine.
Yup - HACS fix is out
