I’ve had frigate for a while now and recently just chaged my config to use go2rtc but I’m getting constant high CPU usage between 80%-99%.
I have 4 cameras with average CPU usage like below:
ffmpeg: 17%
capture: 6%
detect: 3%
Hardware
- RPI4 8GB
- Coral USB
- Samsung T7 1TB SSD
- Dahua cameras
I am using Home Assistant OS and my sub stream is set to the correct resolution with AAC audio.
Can anyone help figure out what may be causing this?
mqtt:
host: 192.168.1.118
user: mqtt-user
password: password
ffmpeg:
hwaccel_args: preset-rpi-64-h264
go2rtc:
streams:
WALKWAY_SUB: # <- for RTSP streams
- rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=2
WALKWAY: # <- for RTSP streams
- rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
FRONT_DOOR_SUB: # <- for other streams
FRONT_DOOR: # <- for other streams
DRIVEWAY_LEFT_SUB: # <- for RTSP streams
DRIVEWAY_LEFT: # <- for RTSP streams
DRIVEWAY_RIGHT_SUB: # <- for other streams
DRIVEWAY_RIGHT: # <- for other streams
cameras:
WALKWAY:
ffmpeg:
inputs:
- path: rtsp://192.168.1.118:8554/WALKWAY_SUB
input_args: preset-rtsp-restream
roles:
- detect
roles:
- record
detect:
width: 640
height: 480
fps: 5
motion:
mask:
- 0,0,640,0,640,92,0,252
objects:
track:
- person
- dog
- bicycle
snapshots:
enabled: true
timestamp: false
bounding_box: true
crop: False
retain:
default: 120
record:
enabled: true
events:
pre_capture: 3
post_capture: 3
retain:
default: 120
mode: active_objects
FRONT_DOOR:
ffmpeg:
inputs:
- path: rtsp://192.168.1.118:8554/FRONT_DOOR_SUB
roles:
- detect
roles:
- record
detect:
width: 640
height: 480
fps: 5
motion:
mask:
- 117,57,255,236,401,123,521,200,640,170,640,0,136,0,0,0,46,120
objects:
track:
- person
- dog
- cat
- bird
- bicycle
snapshots:
enabled: True
timestamp: false
bounding_box: True
crop: False
retain:
default: 120
record:
enabled: true
events:
pre_capture: 3
post_capture: 3
retain:
default: 120
DRIVEWAY_LEFT:
ffmpeg:
inputs:
- path: rtsp://192.168.1.118:8554/DRIVEWAY_LEFT_SUB
roles:
- detect
roles:
- record
detect:
width: 640
height: 480
fps: 5
motion:
mask:
- 640,242,497,197,503,79,430,67,116,115,0,166,0,0,341,0,640,0
objects:
track:
- person
- dog
- cat
- bird
- bicycle
snapshots:
enabled: true
timestamp: false
bounding_box: True
crop: False
retain:
default: 120
record:
enabled: true
events:
pre_capture: 3
post_capture: 3
retain:
default: 120
DRIVEWAY_RIGHT:
ffmpeg:
inputs:
- path: rtsp://192.168.1.118:8554/DRIVEWAY_RIGHT_SUB
roles:
- detect
roles:
- record
detect:
width: 640
height: 480
fps: 5
motion:
mask:
- 0,0,640,0,640,139,438,71,243,133,0,156
objects:
track:
- person
- dog
- cat
- bird
- bicycle
snapshots:
enabled: true
timestamp: false
bounding_box: true
crop: False
retain:
default: 120
record:
enabled: true
events:
pre_capture: 3
post_capture: 3
retain:
default: 120
detectors:
coral:
type: edgetpu
device: usb
