I installed Frigate on Home Assistant Blue and have two cameras working. I have a Coral TPU plugged into a USB3 port and is seems to be working.
~ $ lsusb
Bus 002 Device 004: ID 18d1:9302
Bus 002 Device 002: ID 05e3:0620
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 05e3:0610
Bus 002 Device 001: ID 1d6b:0003
I am unable to find the proper value for hwaccel_args
. If I leave out the ffmpeg
key altogether, everything works but I get a warning about not having a GPU.
WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended.
This clip from the log shows the warning and the message that the TPU was found.
2024-11-03 22:25:41.905386941 [2024-11-03 14:25:41] frigate.util.services WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
2024-11-03 22:25:42.318449113 [h264 @ 0x274a42c0] Overread VUI by 8 bits
2024-11-03 22:25:45.113397904 [h264 @ 0x272acf40] Overread VUI by 8 bits
2024-11-03 22:25:46.707508655 [INFO] Starting go2rtc healthcheck service...
2024-11-03 22:25:46.948848773 [2024-11-03 14:25:46] peewee_migrate.logs INFO : Starting migrations
2024-11-03 22:25:46.951650040 [2024-11-03 14:25:46] peewee_migrate.logs INFO : There is nothing to migrate
2024-11-03 22:25:46.964795165 [2024-11-03 14:25:46] frigate.app INFO : Recording process started: 409
2024-11-03 22:25:46.982707532 [2024-11-03 14:25:46] frigate.app INFO : Recording process started: 410
2024-11-03 22:25:46.989690303 [2024-11-03 14:25:46] frigate.app INFO : go2rtc process pid: 98
2024-11-03 22:25:47.050402591 [2024-11-03 14:25:47] detector.coral INFO : Starting detection process: 438
2024-11-03 22:25:47.056317183 [2024-11-03 14:25:47] frigate.detectors.plugins.edgetpu_tfl INFO : Attempting to load TPU as usb
2024-11-03 22:25:49.825962080 [2024-11-03 14:25:47] frigate.app INFO : Output process started: 440
2024-11-03 22:25:49.827359318 [2024-11-03 14:25:47] frigate.app INFO : Camera processor started for pool: 457
2024-11-03 22:25:49.828110481 [2024-11-03 14:25:47] frigate.app INFO : Camera processor started for driveway: 458
2024-11-03 22:25:49.829134074 [2024-11-03 14:25:47] frigate.app INFO : Capture process started for pool: 459
2024-11-03 22:25:49.829995285 [2024-11-03 14:25:47] frigate.app INFO : Capture process started for driveway: 469
2024-11-03 22:25:49.830857537 [2024-11-03 14:25:49] frigate.comms.mqtt ERROR : Unable to publish to driveway/all: client is not connected
2024-11-03 22:25:49.831604033 [2024-11-03 14:25:49] frigate.comms.mqtt ERROR : Unable to publish to driveway/motion: client is not connected
2024-11-03 22:25:49.832228981 [2024-11-03 14:25:49] frigate.detectors.plugins.edgetpu_tfl INFO : TPU found
My configuration file is:
detectors:
coral:
type: edgetpu
device: usb
mqtt:
enabled: true
host: worldofmaze.duckdns.org
port: 1883
topic_prefix: frigate
client_id: frigate
user: homeassistant
password: redacted
stats_interval: 60
cameras:
pool:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]/h264Preview_01_sub
roles:
- record
- detect
- rtmp
driveway:
ffmpeg:
inputs:
roles:
- record
- detect
- rtmp
record:
enabled: true
retain:
days: 7
mode: motion
events:
retain:
default: 14
mode: active_objects
objects:
track:
- person
- dog
- cat
filters:
person:
# Optional: minimum width*height of the bounding box for the detected object (default: 0)
min_area: 0
# Optional: maximum width*height of the bounding box for the detected object (default: 24000000)
max_area: 100000
# Optional: minimum score for the object to initiate tracking (default: shown below)
min_score: 0.5
# Optional: minimum decimal percentage for tracked object's computed score to be considered a true positive (default: shown below)
threshold: 0.7
version: 0.14
Any help getting the TPU working would be appreciated.
Thanks in advance.
