Frigate integration created about 35M rows and a 40GB DB!
Currently clearing it using the recorder purge service. This is what it looks like after running it for 48 hours
MariaDB [(none)]> USE homeassistant;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
MariaDB [homeassistant]> SELECT      table_name AS "Table",      ROUND(((data_length + index_length) / 1024 / 1024), 2) AS "Size (MB)",      ROUND(data_free / 1024 / 1024, 2) AS "Free/Reclaimable Space (MB)"  FROM information_schema.TABLES  WHERE table_schema = "homeassistant"    AND table_name = "states";
| Table  | Size (MB) | Free/Reclaimable Space (MB) |
| states |  38181.56 |                      274.00 |
1 row in set (0.004 sec)
Here’s a filesystem view:
core-mariadb:/data/databases/homeassistant# ls -lhSr                     total 41G
-rw-rw----    1 root     root          67 Jul  8  2024 db.opt
-rw-rw----    1 root     root        1005 Nov 22 13:09 schema_changes.frm-rw-rw----    1 root     root        1.4K Nov  9 04:38 statistics_runs.frm
-rw-rw----    1 root     root        1.5K Nov  9 04:35 event_data.frm
-rw-rw----    1 root     root        1.5K Nov  9 04:35 state_attributes.frm
-rw-rw----    1 root     root        1.5K Nov  9 04:35 recorder_runs.frm
-rw-rw----    1 root     root        1.7K Nov 22 13:09 event_types.frm
-rw-rw----    1 root     root        1.9K Nov 22 13:09 migration_changes.frm
-rw-rw----    1 root     root        2.3K Nov  9 04:38 statistics_short_term.frm
-rw-rw----    1 root     root        2.3K Nov  9 04:35 statistics.frm
-rw-rw----    1 root     root        2.4K Nov 22 13:09 states_meta.frm
-rw-rw----    1 root     root        3.3K Nov  9 04:35 events.frm
-rw-rw----    1 root     root        5.0K Nov 22 08:45 states.frm
-rw-rw----    1 root     root        5.7K Nov 22 13:10 statistics_meta.frm
-rw-rw----    1 root     root       96.0K Nov 22 13:09 schema_changes.ibd-rw-rw----    1 root     root       96.0K Nov 22 13:10 migration_changes.ibd
-rw-rw----    1 root     root      112.0K Nov 22 18:00 recorder_runs.ibd
-rw-rw----    1 root     root      112.0K Nov 22 13:09 event_types.ibd
-rw-rw----    1 root     root      352.0K Nov 24 22:51 statistics_runs.ibd
-rw-rw----    1 root     root        7.0M Nov 22 17:33 statistics_meta.ibd
-rw-rw----    1 root     root        9.0M Nov 24 07:06 states_meta.ibd
-rw-rw----    1 root     root       11.0M Nov 24 22:37 event_data.ibd
-rw-rw----    1 root     root       29.0M Nov 24 22:49 events.ibd
-rw-rw----    1 root     root      268.0M Nov 24 22:51 state_attributes.ibd
-rw-rw----    1 root     root      520.0M Nov 24 22:51 statistics_short_term.ibd
-rw-rw----    1 root     root        1.9G Nov 24 22:02 statistics.ibd
-rw-rw----    1 root     root       38.1G Nov 24 22:51 states.ibd
Here are a few top entities with counts. Hopefully the purge will finish in a month or so and then I will optimize the db
MariaDB [homeassistant]> SELECT metadata_id, count(*) FROM states            -> WHERE metadata_id IN (
    ->     37679, 37680, 37688, 37684, 37681, 37686, 37675, 37687,
    ->     37674, 37685, 37678, 37683, 37677, 39199, 38649, 38109,
    ->     38110, 38111, 38112, 38113, 38114, 38115, 38116, 38117,
    ->     38060, 38061, 38062, 38063, 38064, 38065, 38066, 38067, 38068
    -> GROUP BY metadata_id
    -> ORDER BY count(*) DESC;
| metadata_id | count(*) |
|       37687 |   612049 |
|       37686 |   611580 |
|       37688 |   611580 |
|       37685 |   567723 |
|       39199 |     2396 |
|       38116 |     2310 |
|       38109 |     2310 |
|       38110 |     2310 |
|       38111 |     2310 |
|       38112 |     2310 |
|       38113 |     2310 |
|       38114 |     2310 |
|       38115 |     2310 |
|       38060 |     2308 |
|       38068 |     2308 |
|       38061 |     2308 |
|       38062 |     2308 |
|       38063 |     2308 |
|       38064 |     2308 |
|       38065 |     2308 |
|       38066 |     2308 |
|       38067 |     2308 |
|       38117 |     2182 |
|       38649 |     1161 |
24 rows in set (3.735 sec)
Will keep reporting every 8-24 hours just for the sake of it lol
