Frigate integration faled to connect
Setup:
Unraid (version 6.12.14) running Home Assistant OS ( Core2025.1.1, Supervisor2024.12.3, Operating System14.1, Frontend20250106.0) and Frigate (o.14.1 release) as docket install. Frigate is not installed as a add-on.
Problem:
Frigate integration fails to connect to the Frigate docker instance. Error message “Failed to connect”
If I use URL in the browser, then I can access Frigate correctly.
Troubleshooting:
I used wireshark packet sniffer, I could not see any request send from the Frigate integration to the configured external URL.
For the test purpose I installed Frigate as a HAOS add-on. In that case integration works correctly.
Is there any issue with the Frigate integration connecting to the Frigate docker instance? Does is work only with the Frigate installed as a local add-on?
I have the same problem, does anyone know what this could be due to?
