I have just installed Frigate on my Pi4 with HASSOS. Am running 2021.
Hass Core: core-2021.4.4
Frigate version: 1.14
Sometimes i can get it to start, but i get a corrupted video feed, and before long the add-on crashes.
Log File:
* Starting nginx nginx
...done.
frigate.app INFO : Creating directory: /tmp/cache
Starting migrations
peewee_migrate INFO : Starting migrations
There is nothing to migrate
peewee_migrate INFO : There is nothing to migrate
detector.coral INFO : Starting detection process: 36
frigate.edgetpu INFO : Attempting to load TPU as usb
frigate.app INFO : Camera processor started for back: 39
frigate.app INFO : Capture process started for back: 41
frigate.edgetpu INFO : No EdgeTPU detected.
Process detector:coral:
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 152, in load_delegate
delegate = Delegate(library, options)
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 111, in __init__
raise ValueError(capture.message)
ValueError
File "/usr/lib/python3.8/multiprocessing/process.py", line 315, in _bootstrap
self.run()
File "/usr/lib/python3.8/multiprocessing/process.py", line 108, in run
self._target(*self._args, **self._kwargs)
File "/opt/frigate/frigate/edgetpu.py", line 124, in run_detector
object_detector = LocalObjectDetector(tf_device=tf_device, num_threads=num_threads)
File "/opt/frigate/frigate/edgetpu.py", line 63, in __init__
edge_tpu_delegate = load_delegate('libedgetpu.so.1.0', device_config)
File "/usr/local/lib/python3.8/dist-packages/tflite_runtime/interpreter.py", line 154, in load_delegate
raise ValueError('Failed to load delegate from {}\n{}'.format(
ValueError: Failed to load delegate from libedgetpu.so.1.0
frigate.mqtt INFO : MQTT connected
frigate.yml:
mqtt:
host: 192.168.***.***
user: *******
password: *******
cameras:
back:
ffmpeg:
inputs:
- path: rtsp://*username**:**pass**@192.168.***.***:554/ch01/1
roles:
- detect
- rtmp
width: 1920
height: 1088
fps: 5
Any ideas?
