I have a Raspberry Pi 4 running on The HA OS. I also have Frigate installed as an Add-on and have installed the Integration on HACS.
When I then add the HA Integration, at the Submit point (connecting to http://ccab4aaf-frigate:5000) I get the error “Failed to connect”. Also I cannot connect via http://x.x.x.x:5000 or https://x.x.x.x:5000 either. However I can connect via the HA sidebar ok.
Separate to the above I have previously installed the NGINX Home Assistant SSL proxy. This was specifically to do with my ESPHome installation (if I recall correctly that mandated an https connection).
I’m suspicous that the https configuration for my HA is what is preventing my Frigate HA Integration from working?
Re. the logs the Frigate logs don’t show anything relating to IP addresses except 127.0.0.1, i.e. localhost.
The main HA logs do show this
Error fetching information from http://ccab4aaf-frigate:5000/api/stats: Cannot connect to host ccab4aaf-frigate:5000 ssl:default [Name does not resolve]
Any thoughts appreciated.
