I can’t get Frigate to start. It seems like this may have started after updating to 2024.8.1 but can’t be sure. Here is my Frigate log.
2024-08-14 17:46:36.778872223 [INFO] Got WebRTC port from supervisor: 8555
2024-08-14 17:46:37.027813090 [INFO] Starting go2rtc...
2024-08-14 17:46:37.094416563 12:46:37.094 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2024-08-14 17:46:37.094419895 12:46:37.094 INF config path=/dev/shm/go2rtc.yaml
2024-08-14 17:46:37.094631308 12:46:37.094 INF [rtsp] listen addr=:8554
2024-08-14 17:46:37.094681567 12:46:37.094 INF [api] listen addr=:1984
2024-08-14 17:46:37.094718917 12:46:37.094 INF [webrtc] listen addr=:8555/tcp
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
s6-rc: info: service certsync successfully started
s6-rc: info: service legacy-services: starting
2024-08-14 17:46:37.104544514 [INFO] Starting certsync...
s6-rc: info: service legacy-services successfully started
2024-08-14 17:46:37.151358937 127.0.0.1 - - [14/Aug/2024:12:46:37 -0500] "" 400 0 "-" "-" "-"
2024-08-14 17:46:37.607928939 [2024-08-14 12:46:37] frigate.app INFO : Starting Frigate (0.14.0-da913d8)
2024-08-14 17:46:37.607973185 [2024-08-14 12:46:37] frigate.app INFO : Creating directory: /tmp/cache
2024-08-14 17:46:37.608010331 [2024-08-14 12:46:37] frigate.util.config INFO : Checking if frigate config needs migration...
2024-08-14 17:46:37.646394334 [2024-08-14 12:46:37] frigate.util.config INFO : frigate config does not need migration...
2024-08-14 17:46:37.666199848 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 0,2160 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666246270 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 986,2160 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666278520 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3461,865 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666308132 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3605,237 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666336225 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 2848,0 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666364762 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 2818,2160 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666391831 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 2970,1931 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666417258 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3212,1494 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666443312 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3359,1181 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666469027 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3481,738 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666493753 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3588,257 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666521785 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3840,252 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666547112 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 3840,2160 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666571922 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 2234,1105 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666596144 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 2376,1269 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666626959 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 1802,1467 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666652107 [2024-08-14 12:46:37] frigate.util.config ERROR : Not applying mask due to invalid coordinates. 1682,1239 is outside of the detection resolution 1920x1080. Use the editor in the UI to correct the mask.
2024-08-14 17:46:37.666677610 *************************************************************
2024-08-14 17:46:37.666680298 *************************************************************
2024-08-14 17:46:37.666680893 *** Your config file is not valid! ***
2024-08-14 17:46:37.666681578 *** Please check the docs at ***
2024-08-14 17:46:37.666684352 *** https://docs.frigate.video/configuration/index ***
2024-08-14 17:46:37.666684935 *************************************************************
2024-08-14 17:46:37.666685511 *************************************************************
2024-08-14 17:46:37.666689424 *** Config Validation Errors ***
2024-08-14 17:46:37.666690805 *************************************************************
2024-08-14 17:46:37.666694342 could not convert string to float: ''
2024-08-14 17:46:37.667096727 Traceback (most recent call last):
2024-08-14 17:46:37.667097804 File "/opt/frigate/frigate/app.py", line 645, in start
2024-08-14 17:46:37.667098340 self.init_config()
2024-08-14 17:46:37.667098971 File "/opt/frigate/frigate/app.py", line 140, in init_config
2024-08-14 17:46:37.667099525 self.config = user_config.runtime_config(self.plus_api)
2024-08-14 17:46:37.667100201 File "/opt/frigate/frigate/config.py", line 1552, in runtime_config
2024-08-14 17:46:37.667100779 camera_config.objects.filters[object] = RuntimeFilterConfig(
2024-08-14 17:46:37.667110864 File "/opt/frigate/frigate/config.py", line 548, in __init__
2024-08-14 17:46:37.667111645 config["mask"] = create_mask(frame_shape, mask)
2024-08-14 17:46:37.667112270 File "/opt/frigate/frigate/util/image.py", line 723, in create_mask
2024-08-14 17:46:37.667112889 add_mask(m, mask_img)
2024-08-14 17:46:37.667113495 File "/opt/frigate/frigate/util/image.py", line 741, in add_mask
2024-08-14 17:46:37.667127363 [
2024-08-14 17:46:37.667128202 File "/opt/frigate/frigate/util/image.py", line 743, in <listcomp>
2024-08-14 17:46:37.667129309 int(float(points[i]) * mask_img.shape[1]),
2024-08-14 17:46:37.667129980 ValueError: could not convert string to float: ''
2024-08-14 17:46:37.667136639
2024-08-14 17:46:37.667140819 *************************************************************
2024-08-14 17:46:37.667141740 *** End Config Validation Errors ***
2024-08-14 17:46:37.667142556 *************************************************************
2024-08-14 17:46:38.819145024 [INFO] Service Frigate exited with code 1 (by signal 0)
Any idea how to fix this?
