Ok, Frigate was hard enough for me to use and it took me weeks and weeks to get it running with my 4 cameras, get them recording, saving on network drive, etc.
Then, I don’t even know when, but I’m thinking a week or so ago, it just stopped working. I don’t know enough about this to even describe what’s going on, but it’ll barely load, and when it does, none of the live view cameras seem to work. The only way I even got it to load was by removing the previous:
ui:
live_mode: webrtc
Was there an update and now the config.yaml file needs reworked? And if so, that’s complete crap, it should be a set it and forget it, I shouldn’t have to try and figure out how to code this every month or two. I’m not a programmer.
Sorry for my frustration, this stuff is so hard, I’m probably in over my head, but geez, I just want some working cameras. I’ll post my config file, but I don’t have a clue what hardly any of this means.
It’s even acting like my CoralTPU isn’t loaded, but I’ve literally changed nothing on my system
2024-07-12 05:08:53.133470767 [INFO] Preparing Frigate...
2024-07-12 05:08:53.145739085 [INFO] Starting Frigate...
2024-07-12 05:08:54.549000030 [2024-07-12 01:08:54] frigate.app INFO : Starting Frigate (0.13.2-6476f8a)
2024-07-12 05:08:54.549092425 [2024-07-12 01:08:54] frigate.app INFO : Creating directory: /tmp/cache
2024-07-12 05:08:54.621067243 [2024-07-12 01:08:54] peewee_migrate.logs INFO : Starting migrations
2024-07-12 05:08:54.625011511 [2024-07-12 01:08:54] peewee_migrate.logs INFO : There is nothing to migrate
2024-07-12 05:08:54.629278139 [2024-07-12 01:08:54] frigate.app INFO : Recording process started: 451
2024-07-12 05:08:54.631633766 [2024-07-12 01:08:54] frigate.app INFO : go2rtc process pid: 89
2024-07-12 05:08:54.652884921 [2024-07-12 01:08:54] detector.coral INFO : Starting detection process: 461
2024-07-12 05:08:54.654408607 [2024-07-12 01:08:54] frigate.app INFO : Output process started: 463
2024-07-12 05:08:54.655533770 [2024-07-12 01:08:54] frigate.detectors.plugins.edgetpu_tfl INFO : Attempting to load TPU as usb
2024-07-12 05:08:54.655652259 [2024-07-12 01:08:54] frigate.detectors.plugins.edgetpu_tfl ERROR : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2024-07-12 05:08:54.655706971 Process detector:coral:
2024-07-12 05:08:54.656664540 Traceback (most recent call last):
2024-07-12 05:08:54.656685149 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2024-07-12 05:08:54.656686925 delegate = Delegate(library, options)
2024-07-12 05:08:54.656688861 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2024-07-12 05:08:54.656692986 raise ValueError(capture.message)
2024-07-12 05:08:54.656694938 ValueError
2024-07-12 05:08:54.656707491
2024-07-12 05:08:54.656709626 During handling of the above exception, another exception occurred:
2024-07-12 05:08:54.656711325
2024-07-12 05:08:54.656712741 Traceback (most recent call last):
2024-07-12 05:08:54.656747047 File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2024-07-12 05:08:54.656750237 self.run()
2024-07-12 05:08:54.656752575 File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2024-07-12 05:08:54.656754691 self._target(*self._args, **self._kwargs)
2024-07-12 05:08:54.656756863 File "/opt/frigate/frigate/object_detection.py", line 102, in run_detector
2024-07-12 05:08:54.656759098 object_detector = LocalObjectDetector(detector_config=detector_config)
2024-07-12 05:08:54.656779330 File "/opt/frigate/frigate/object_detection.py", line 53, in __init__
2024-07-12 05:08:54.656781509 self.detect_api = create_detector(detector_config)
2024-07-12 05:08:54.656783177 File "/opt/frigate/frigate/detectors/__init__.py", line 18, in create_detector
2024-07-12 05:08:54.656784643 return api(detector_config)
2024-07-12 05:08:54.656786326 File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 41, in __init__
2024-07-12 05:08:54.656788098 edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2024-07-12 05:08:54.656789808 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2024-07-12 05:08:54.656812573 raise ValueError('Failed to load delegate from {}\n{}'.format(
2024-07-12 05:08:54.656814674 ValueError: Failed to load delegate from libedgetpu.so.1.0
2024-07-12 05:08:54.656815974
2024-07-12 05:08:55.026034641 [2024-07-12 01:08:55] frigate.app INFO : Camera processor started for garage_exterior: 485
2024-07-12 05:08:55.026148820 [2024-07-12 01:08:55] frigate.app INFO : Camera processor started for garage_interior: 486
2024-07-12 05:08:55.033319536 [2024-07-12 01:08:55] frigate.app INFO : Camera processor started for front_porch: 488
2024-07-12 05:08:55.040581629 [2024-07-12 01:08:55] frigate.app INFO : Camera processor started for back_deck: 490
2024-07-12 05:08:55.047948500 [2024-07-12 01:08:55] frigate.app INFO : Capture process started for garage_exterior: 492
2024-07-12 05:08:55.055206006 [2024-07-12 01:08:55] frigate.app INFO : Capture process started for garage_interior: 494
2024-07-12 05:08:55.063073251 [2024-07-12 01:08:55] frigate.app INFO : Capture process started for front_porch: 497
2024-07-12 05:08:55.072174773 [2024-07-12 01:08:55] frigate.app INFO : Capture process started for back_deck: 501
If you need my config file, I can post that too.
