I’ve got Frigate setup on a separate Raspberry Pi and am using MQTT in HA and the HACS Frigate integration to bring everything into HA. HA shows all the entities and most of them work. I can go into the Media Browser and playback clips no problem. However, trying to view the entity for the live feed does not work. I’ve tried setting the RTMP URL template to rtmp://192.168.50.1:5000/live/{{ name }}, but it makes no difference. Any ideas on what’s wrong or next steps on diagnosing the problem?
Frigate: 192.168.50.1
HA: 192.168.1.250
Firewall rule in place to allow all traffic between the two subnets for now.
Frigate.yml
version: "3.9"
services:
frigate:
container_name: frigate
privileged: true # this may not be necessary for all setups
restart: unless-stopped
image: blakeblackshear/frigate:stable-armv7
shm_size: "256mb" # update for your cameras based on calculation above
devices:
- /dev/bus/usb:/dev/bus/usb # passes the USB Coral, needs to be modified for other versions
volumes:
- /etc/localtime:/etc/localtime:ro
- /home/administrator:/config
- /mnt/nvr:/media/frigate
- /etc/frigate:/db
- type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
target: /tmp/cache
tmpfs:
ports:
- "1935:1935" # RTMP feeds
- "5000:5000"
- "5001:5001"
- "8080:8080"
environment:
FRIGATE_RTSP_PASSWORD: "Redacted"
mqtt:
container_name: mqtt
image: eclipse-mosquitto
ports:
- "1883:1883"
Config.yaml
# yaml-language-server: $schema=http://192.168.50.1:5000/api/config/schema
#logger:
# default: debug
mqtt:
host: 192.168.1.250
user: mqtt
password: Redacted
cameras:
front_camera:
ffmpeg:
inputs:
- path: rtsp://Redacted:{FRIGATE_RTSP_PASSWORD}@192.168.50.10:554/cam/realmonitor?channel=1&subtype=0
roles:
- record
inputs:
- path: rtsp://Redacted:{FRIGATE_RTSP_PASSWORD}@192.168.50.10:554/cam/realmonitor?channel=1&subtype=1
roles:
- rtmp
inputs:
- path: rtsp://Redacted:{FRIGATE_RTSP_PASSWORD}@192.168.50.10:554/cam/realmonitor?channel=1&subtype=2
roles:
- detect
detect:
width: 1280
height: 720
fps: 30
enabled: True
max_disappeared: 150
record:
enabled: True
retain:
days: 30
rtmp:
enabled: True
mqtt:
enabled: True
timestamp: True
bounding_box: True
crop: True
height: 270
objects:
track:
- person
- car
- bicycle
- motorcycle
- cat
- dog
filters:
person:
min_area: 5000
max_area: 100000
min_score: 0.5
threshold: 0.7
detectors:
coral:
type: edgetpu
device: usb
