Frigate Lovelace card showing blank camera
We had a power cut during the night and now the Frigate card shows only a blank green screen. I rebooted Frigate and checked the camera integration and MQTT and they’re OK. I can access the camera directly via its IP address but I’m not sure what to look for in HA. All my other devices and services are working. Probably something simple.
edit: Found it! I noticed in the log that the camera IP address changed. I updated the config and it’s back. My camera is Ethernet connected. Would the IP address change after the power cut? Maybe I should make the address static or reserve it in my router?
ip address changing is not surprising, definitely should have cameras on static IP and not allow it to connect to the internet
Right. I changed it to static. I don’t believe it’s exposed to the internet, just my home network.
