Hi all,
I have been troubleshooting an issue where the FPS is fine in Frigate but the HA card is a lot slower, around 1-2FPS. I have this card on a tablet showing two cameras, one at a time. Both camera’s are USB cameras on a Dell OptiPlex running Proxmox with Frigate in an LXC. I have tried many settings and options but so far nothing seems to fix the issue.
I have had no success with recording or detection so far, so I have disabled both for the time being.
Card config:
type: custom:frigate-card
cameras:
- go2rtc:
modes:
- webrtc
stream: back
webrtc_card: {}
live_provider: webrtc-card
camera_entity: camera.back
- camera_entity: camera.door
go2rtc:
modes:
- webrtc
stream: door
view:
default: live
dark_mode: 'off'
scan:
enabled: true
live:
lazy_unload: hidden
layout:
fit: fill
preload: true
lazy_load: false
zoomable: false
auto_play: all
dimensions:
aspect_ratio: '9:16'
performance:
style:
border_radius: true
box_shadow: true
profile: high
view_layout:
position: cameras
Frigate config:
mqtt:
host: 10.0.3.1
user: frigate
password: njRVF6QHHs7cQ9ag
birdseye:
enabled: True
restream: False
width: 1280
height: 720
quality: 4
mode: continuous
go2rtc:
streams:
back: ffmpeg:device?video=0&video_size=1280x720&framerate=20#video=h264#raw=-pix_fmt yuv420p#rotate=90
door: ffmpeg:device?video=2&video_size=1280x720&framerate=20#video=h264#raw=-pix_fmt yuv420p#rotate=90
webrtc:
candidates:
- 10.0.200.23:8555
- stun:8555
cameras:
back:
ffmpeg:
output_args:
record: preset-record-generic-audio-copy
inputs:
- path: rtsp://127.0.0.1:8554/back
input_args: preset-rtsp-restream
roles:
- rtmp
door:
ffmpeg:
output_args:
inputs:
- path: rtsp://127.0.0.1:8554/door
roles:
- rtmp
detectors:
ov:
type: openvino
device: AUTO
model:
path: /openvino-model/ssdlite_mobilenet_v2.xml
model:
width: 300
height: 300
input_tensor: nhwc
input_pixel_format: bgr
labelmap_path: /openvino-model/coco_91cl_bkgr.txt
detect:
enabled: False
Thanks a lot!
