Frigate Mobile App Notifications 2.0
Got it working now. Thanks! Now I hope the iOS clip streaming issue is fixed in the integration before I can port the potential fix you have.
So been digging into this, looks like there in a ā€œtimeout: 30ā€ meant for Android TV. My notification group includes a TV (Pixel/iPhone/ShieldTV/HASS.Agent). The timeout seems to impact my Pixels notifications too. I feel like this all started happening around the time I updated to Android 15 which seems to have some tweaks to notifications. Not sure if anyone else can verify (turn on TV notifications with an android 15 device). In the short term it looks like I have a solution, worst case I will take my TV out of the group.
I also am having the exact same issue on HA 2025.1 Frigate .15 beta 4
This is through the spook integration as well
The repair item?
Great, so HA continues to add verifications that break blueprint flexibility.
Nothing is broken I donā€™t think. I can just ignore it
How come in the 0.14 branch, there is no update sub-label to support Double Take face recognition?
Because it isnā€™t optional in that branch, if you have it setup it will work.
Okay weird, I am getting sub label updates back in frigate but I can never see the person label replaced. I need to debug and play with it some more.
It certainly doesnā€™t get replaced every time, probably depends on how quickly it gets labelled, but the code works, definitely.
Is Frigate Notifications (0.14.0.1g) the latest one? I found it in a post here, but donā€™t actually see it in the repo. Am I missing something?
Happy to report the new 5.7.0 frigate integration fixes the iOS streaming issue with frigate 15 using the m3u stream. I manually ported the fix over to 0.14.0.1g blueprint and it worked.
Great thanks, Iā€™ll publish it tonight.
Also expect frigate 0.14 reviews version will move to beta this week and current beta will become stable.
Hi I am trying to just get notified on reviews as when I was using frigate/events it was sending notifications for too many false positives. I still get too many as I get notified for reviews topics that are severity=detection and Iā€™d like to filter to only severity=alerts. Would the custom filter be able to accommodate this and if so, how?
Frigate 0.14.1
The 0.14 reviews based beta that was mentioned should solve this. No need to add cooldown timers, etc.
Iā€™ve been trying to incorporate the LLMVision analysers w/ this as this Frigate blueprint works great. But can not get it to work, only thing i can do is run both, but the timing is off, so LLM updates a helper text and that feeds into the Frigate blueprint but the LLM update isnt done before the notification is sent out. Anyone have insights on how I can unify these so I can have the text in the Frigate blueprint be generated by LLMVision?
Using the 0.14 branch is there anyway to get rid of the duplicate ā€œwas detectedā€¦ā€ would be nice if it updated the current notification or something.
Explain?
It does update the existing notification
Hello and thanks for creating this blueprint.
Is there a way to make the android notifications persistent? They do work but sometimes disappear before I get a chance to look at them.
Thank you!
That must be something with your device. They are standard notifications which are persistent. You can enable the sticky function which may stop you accidentally clearing them maybe.
I get two separate notifications:
  • Person detected
  • Person was detected
I tried to remove the optional ā€œwasā€ template but then I got two Person detected for every review.
I do have ā€œAlert Onceā€ enabled so Iā€™ll try running without that.
Attached is an example from the companion app notification history.
