Frigate Mobile App Notifications 2.0
Thanks. I got it working. I think another automation was messing with it. Im not a big fan of the flow though and waiting for some web page to load. Heck, on my iphone, the video even loads all smooshed up and have to click full screen for it to load, then hit play.
Does anyone have this working with the frigate 0.12 beta? I tried the beta, but the notifications didnā€™t include the clips/snapshots.
Yes, which blueprint are you using?
Iā€™m running Frigate Notification (0.11.0.10) - SgtB
Iā€™ve been using that with frigate 0.12 beta 5 and 7 sor far.
If you can provide the config of the automation and look for any errors too we can work it out.
For me Frigate Notification (0.11.0.10) - SgtB doenā€™t work but this fix does:
Frigate Mobile App Notifications - #568 by SgtBatten
here is my config
alias: Frigate Notification Camera HikVision Rue Test new BluePrint
description: ''
use_blueprint:
  path: SgtBatten/frigate_0.11_notification.yaml
  input:
    tv_transparency: 0%
    camera: camera.camera_hikvision_rue_frigate
    notify_device: **********************
    critical: 'true'
Please try the lastest Version 0.11.0.12
Thatā€™s the version I have actually.
Wrong copy paste, sorry
[EDIT]
the last beta does not work either
Please check the traces to see where it is failing. If you have no traces then please confirm the camera name in frigate is camera_hikvision_rue_frigate
It doesnā€™t get triggered.
in Frigate, the camera is Camera_HikVision_Rue.
The name you have is the entity name picked by your Blueprint from the Frigate integration. I changed it manually there.
Why does the entity id in the automation have _frigate at the end?
It needs to match the frigate config (capitals are okay).
Edit: oh did you change the entity id in the frigate integration?
Try setting in yaml mode of the automation to match the frigate config.
Im experiencing that sgtbatten blueprint make notifications before the Detection have been confirmed. I get pop up with a picture and when i wanna see video og snapshot its not thereā€¦ And the video etc. Is not in frigate either. How do I avoid these false notifications?
editing in yaml fixed it
May I suggest to add a note in your Blueprint to highlight that if entites were modified, it requires some editing in yaml?
@SgtBatten Thanks for your support BTW
Yes I will add a note.
There will always be a slight delay before the video is available. The notification is meant to trigger immediately, and the videos will be available as soon as frigate saves the first segment of the event.
I very rarely get a snapshot with no video. This usually means your snapshot settings are different to your event settings in frigate.
Are you saying all notifications are like this?
Hello, how and where did you do this? How can I change the blueprint?
Thanks for the solution.
Cheers
A lot has changed since that post. What issue are you currently having?
If you need to edit a blueprint you need access to the blueprint yaml file. If you have a text editor installed within ha this should be easy, they are in config/blueprints/automation
Ok, thanks. It s working now like it should.
I just updated from .08 to .12 on @SgtBattenā€™s version, and Iā€™m no longer getting the snapshot photos in the notification consistently. I get one about every 10 or so notifications. When I look at the jpg url in Traces, Iā€™m able to see the photo fine in a browser.
Please provide the automation config (yaml) as well as a screenshot of the trace graphic when this occurs. Are you on iOS or Android?
