What url opens when you press view snapshot
just done! Let’see
the HA one http://xxxxxx.duckdns.org showing a small blue box with ?
while if I press Clip i can see :
It should be opening a longer url with /api/frigate etc etc.
Edit: if you attempt to edit the url can you see the full url?
you are right:
xxxxx.duckdns.org:8123/api/frigate/notifications/1693896280.197076-sa9ypz/snapshot.jpg
maybe I have understood the problem.
the URL is the one of HA. Should I use the one where Frigate is installed?
somethink like
/volume1/docker/frigate/storage/clips/Piazzale_1-1693908430.559685-oopbcr.jpg
where the file is phisically based?
It works but with the same issue of the beta verion
No, the url is correct. The fact is isn’t working means it is probably something to do with how you reinstalled the frigate integration after moving frigate.
Edit.
Replace the duckdns part with your Lan IP for home assistant and confirm if it works or not.
same issue
Delete the frigate integration. Restart HA.
Install the integration again. See if that gives any improvements.
I’m heading to bed now sorry, but this is almost certainly the primary issue. Some process of disabling entities and deleting them individually etc should allow it to be removed.
Edit:The issue may just be with the new one so check the config if that and remove/reinstall that may help.
It has been difficult but at the end I was able to remove and reinstall the integrate and it works now.
Or almost!
No error, I can see the snapshot. The only remaining issue is the clip that I cannot see.
When I press Clip I continue to see the famous barred triangle.
By the way a reasonable progress
Nice work!.
What is the url it opens when you click on clip?
xxxxx.duckdns.org:8123/api/frigate/notifications/1693983854.322953-jkoifo/piazzale_1/clip.mp4
but the recording in my docker have different names
The names won’t match. It’s done via the API.
Does replacing piazzale_1/clip.mp4 with snapshot.jpg yield the snapshot?
If yes.
Does changing to a capital P do anything?
Piazzale_1/clip.mp4
I just copied that URL on my computer and it works.
the problem seems to be only on my Iphone.
Maybe Iphone cannot manage mp4 files?
Yes I can see the snapshot
No. it works on my computer but not on my Iphone
Is the camera h.265?
