My mistake it does work. Don’t know what I was doing incorrectly. Maybe the other notification automation interfered. Is there a way to see the notification more than once?
even im facing similar issue , automation is not getting triggered, older frigate blueprint 1.0 was working
running everything on docker
HA core: 2023.12.3
frigate HA integration : v4.0.0
frigate : 0.12.1-367D724
mqtt : eclipse-mosquitto:1.6.14
automation configuration :
alias: dummy frigate
description: ""
use_blueprint:
path: SgtBatten/Stable.yaml
input:
camera: camera.frontright_2
base_url: https://home.abc.abc
critical: "true"
labels:
- person
- car
- bus
- motorcycle
notify_device: 876b1565605647606dc65f7e22ee2ba3
message: "test: A Person was detected on the Side camera."
ios_live_view: true
debug: true
color: grey
seeing below error , not sure which client is causing it
2023-12-20T22:06:09.203933730Z 1703109969: New connection from 172.18.0.1 on port 1883.
2023-12-20T22:06:09.204528136Z 1703109969: Client <unknown> disconnected due to protocol error.
2023-12-21T08:46:27.060621137Z 1703148387: Saving in-memory database to /mosquitto/config/mosquitto.db.
Check your camera name
What do you mean?
for the same camera , im able to get notification from old frigate notification blueprint (Frigate Notification Blueprint · GitHub)
camera chosen in 2.0 frigate automation
tried enabling trace , not able to see any activity in log book
notification from older frigate notification blueprint :
In frigate your camera is not numbered 2 right?
It has to match. So delete the _2 from the yaml of the automation, or better yet, rename the entity assuming you don’t have a conflict.
Edit; if you use the beta it would work automatically also.
thanks, beta is working
Being able to click on the notification again and choose clip vs snapshot.
Are you on IOS? Because it already does that on android and I don’t think I can change it for ios
I am desperately trying to make my firetv get notifications. It works with developer tools so the tv can show notifications correctly.
When i enter the name under the phone name i can save the automation, but I can’t leave the phone name empty. marked in yellow.
Can someone post a example of how you configure it?
That would be correct. Mobile device is mandatory now. Group field overrides it though.
You need a baseurl
yes IOS. Thanks for your help and blueprint
Okay, I did try that also. But won’t work. There is no message coming.
Base url is my nabu casa url?
If I want to make a notification group, I still have to do it via configuration.yaml?
Is the automation triggering at all? Do you have traces?
I just deleted the Blueprint and did a fresh installation a new automation.
Looks like it does work now. Sorry for the confusion … ![]()
One more thing, i have an example for the way i tried to generate a group, but this doesn´t work for me. Automation gets triggered but no mesage will show:
#################### Groups ##########
notify:
- platform: group
unique_id: allefernseher
services:
- service: firetv_flur
- service: firetv_schlafen
- service: firetv_wohnen
- platform: group
unique_id: allios
services:
- service: iphone_marcel
- service: malwina_iphone_14
- service: tab9
- service: ipad_468
- service: ipad_air_2
I admit I only have one tv so I’ve never been able to test tv groups. But in theory it should be exactly the same. Is the group loaded properly? I.e has the system bee restarted or otherwise refreshed to ensure it was created? If it’s not new then probably not the issue.
Can i call the group in developer tools? or should i be able to call it?
Yes, you should be able to send a notification via dev tools
What exactly are the subsequent loops? For each notification I receive, I only want to trigger my custom action once (for every notification). I am interpreting it as if I put this in the loop, it could/will trigger multiple times for the same event/notification which I do not want, only on the first notification.
I added a custom action (auto trigger, not on loop) and when my notification fired, the action did not trigger. I checked the trace and the second condition did not pass.
If its the second condition thats causing it to be skipped, something to do with the zones? But if the notification was sent, shouldn’t this go through using the same logic?
Could it be that my notification is only triggered in the loop, after some zone condition eventually passed? If so, then there might not be any way at the moment to trigger the custom action only once per notification if you have zone conditions enabled?
alias: Custom Action Auto
choose:
- conditions:
- '{{ custom_action_auto |length > 0 }}'
{{ not zone_only or (not zone_multi and zones|select('in',
entered_zones)|list|length > 0) or (zone_multi and entered_zones|length
> 0 and zones |reject('in', entered_zones) |list |length == 0) }}
- '{{ not initial_home }}'
- '{{ not state_only or states(input_entity) in states_filter }}'
sequence:
- service: automation.trigger
skip_condition: true
entity_id: automation.show_doorbell_camera
Heres the triggered event
this:
entity_id: automation.doorbell_notification_beta_bp
state: 'on'
attributes:
last_triggered: '2023-12-22T17:39:01.833825+00:00'
mode: parallel
current: 0
max: 10
friendly_name: Doorbell Notification (Beta BP)
last_changed: '2023-12-22T15:45:57.059934+00:00'
last_updated: '2023-12-22T17:39:18.561444+00:00'
context:
parent_id: null
user_id: null
idx: '1'
alias: null
platform: mqtt
topic: frigate/events
payload: >-
{"before": {"id": "1703267289.189675-khmweg", "camera": "doorbell",
"frame_time": 1703267289.189675, "snapshot": null, "label": "person",
"sub_label": null, "top_score": 0.0, "false_positive": true, "start_time":
1703267289.189675, "end_time": null, "score": 0.71484375, "box": [883, 927,
942, 1058], "area": 7729, "ratio": 0.45038167938931295, "region": [765, 829,
1085, 1149], "stationary": false, "motionless_count": 0, "position_changes":
0, "current_zones": [], "entered_zones": [], "has_clip": false,
"has_snapshot": false, "attributes": {}, "current_attributes": []}, "after":
{"id": "1703267289.189675-khmweg", "camera": "doorbell", "frame_time":
1703267289.895963, "snapshot": {"frame_time": 1703267289.895963, "box":
[849, 927, 910, 1099], "area": 10492, "region": [756, 831, 1076, 1151],
"score": 0.76953125, "attributes": []}, "label": "person", "sub_label":
null, "top_score": 0.71484375, "false_positive": false, "start_time":
1703267289.189675, "end_time": null, "score": 0.76953125, "box": [849, 927,
910, 1099], "area": 10492, "ratio": 0.3546511627906977, "region": [756, 831,
1076, 1151], "stationary": false, "motionless_count": 0, "position_changes":
1, "current_zones": [], "entered_zones": [], "has_clip": false,
"has_snapshot": false, "attributes": {}, "current_attributes": []}, "type":
"new"}
qos: 0
description: mqtt topic frigate/events
payload_json:
before:
camera: doorbell
frame_time: 1703267289.189675
snapshot: null
label: person
sub_label: null
top_score: 0
false_positive: true
start_time: 1703267289.189675
end_time: null
score: 0.71484375
box:
- 883
- 927
- 942
- 1058
area: 7729
ratio: 0.45038167938931295
region:
- 765
- 829
- 1085
- 1149
stationary: false
motionless_count: 0
position_changes: 0
current_zones: []
entered_zones: []
has_clip: false
has_snapshot: false
attributes: {}
current_attributes: []
after:
camera: doorbell
frame_time: 1703267289.895963
snapshot:
box:
- 849
- 927
- 910
- 1099
area: 10492
region:
- 756
- 831
- 1076
- 1151
score: 0.76953125
attributes: []
label: person
sub_label: null
top_score: 0.71484375
false_positive: false
end_time: null
score: 0.76953125
box:
- 849
- 927
- 910
- 1099
area: 10492
ratio: 0.3546511627906977
region:
- 756
- 831
- 1076
- 1151
stationary: false
motionless_count: 0
position_changes: 1
current_zones: []
entered_zones: []
has_clip: false
has_snapshot: false
attributes: {}
type: new
input_camera: camera.doorbell
camera: doorbell
mqtt_topic: frigate/events
camera_name: Doorbell
input_base_url: <redacted>
input_client_id: ''
client_id: ''
attachment: snapshot.jpg?bbox=1
alert_once: true
update_thumbnail: true
ios_live_view: ''
android_auto: true
notify_group: Mobile Notify group
notify_group_target: mobile_notify_group
zone_only: true
input_zones:
- walkway
zones:
- walkway
zone_multi: false
input_labels:
- person
labels:
- person
presence_entity: ''
disable_times: []
cooldown: 180
loitering: false
loiter_timer: 0
initial_delay: 0
fps: 5
state_only: false
input_entity: ''
input_states: []
states_filter: []
color: '#03a9f4'
sound: default
sticky: true
tv: false
tv_position: center
tv_size: large
tv_duration: 10
tv_transparency: 0%
tv_interrupt: false
debug: false
Blueprint config
alias: Doorbell Notification (Beta BP)
description: ""
use_blueprint:
path: SgtBatten/Beta.yaml
input:
notify_device: 7a6df43a5b9f64391a2aba46fd7f9fab
title: Front Door Activity
message: A Person was detected at the front door
critical: "false"
alert_once: true
video: >-
{{base_url}}/api/frigate{{client_id}}/notifications/{{id}}/{{camera}}/clip.mp4
android_auto: true
sticky: true
channel: frigate
zone_filter: true
zones:
- walkway
silence_timer: 30
tap_action: "{{base_url}}/api/frigate{{client_id}}/notifications/{{id}}/snapshot.jpg"
url_1: >-
url_3: >-
{{base_url}}/api/camera_proxy_stream/camera.{{trigger.payload_json['after']['camera']
| lower | replace('-','_')}}?token={{state_attr( 'camera.' ~ camera,
'access_token')}}
button_3: View Stream
cooldown: 180
custom_filter: >-
{{ (as_timestamp(now()) -
as_timestamp(states.binary_sensor.front_door_contact.last_changed)) > 240
custom_action_auto:
labels:
- person
