I see the same thing, its not just you Not a fix, but slightly easier than toggling wifi. Go into the IOS HA App > App Configuration > General > Turn off āRemember Last Pageā. Now when you kill the app and re-open it, you will land on the main page.
Thanks Chris your a star, never thought of that, it actually makes my life easier as I often lock the app up testing things I have created that donāt work
I added a channel to this but did not work, any suggest?
ttl: 0
priority: high
channel: alarm_stream
Just wanted to bump this, love this blueprint hi but this clip-escape issue is really strange
The reason it opens in Home Assistant on iOS instead of Safari is because the iOS app tries to be āhelpfulā and opens any links with the same external URL as your HA instance inside the app.
I solved this by creating a new subdomain and proxying it to my HA instance, then setting the new DIFFERENT domain as the ābase URLā in this blueprint. That will force the links to open in Safari. This obviously only works if you arenāt using Nabu Casa remote access.
You can also force the app to open the main dashboard every time in App Configuration ā General ā Uncheck āRemember Last Pageā
I love the blueprint. However, I have zones setup and I still get alerts even though I tell the automation to only alert inside the zone. When viewing the trace, this section
'{{ not zone_only or entered_zones|length > 0 }}'
Shows this result:
" This node was not executed and so no further trace information is available. "
Is it not getting any zone information from the integration?
This blueprint is awesome! Thank you.
Do anyone know if it is possible to internationalize blueprints?
Here is the payload when it alerts:
payload: >-
{"before": {"id": "1630108494.379011-pohik5", "camera": "driveway",
"frame_time": 1630108494.575657, "label": "person", "top_score":
0.68359375, "false_positive": false, "start_time": 1630108494.379011,
"end_time": null, "score": 0.68359375, "box": [485, 67, 511, 151], "area":
2184, "region": [340, 0, 640, 300], "current_zones": [], "entered_zones":
[], "thumbnail": null}, "after": {"id": "1630108494.379011-pohik5",
"camera": "driveway", "frame_time": 1630108498.981612, "label": "person",
"top_score": 0.689453125, "false_positive": false, "start_time":
1630108494.379011, "end_time": null, "score": 0.67578125, "box": [484, 67,
508, 156], "area": 2136, "region": [340, 0, 640, 300], "current_zones":
[], "entered_zones": [], "thumbnail": null}, "type": "update"}
The entered zones is empty yet I have a setting for it not to alert unless entering the zone.
This is the automation config:
description: ''
use_blueprint:
path: hunterjm/frigate_notification.yaml
input:
camera: driveway
notify_device: f4dfb8...c24c6c
zone_filter: true
zones:
- drivewayclosein
labels:
- person
cooldown: 60
Great BluePrint. Thanks for your job.
I donāt know why itās not working for meā¦ My setup is simple as could beā¦ All running on Home Assistant Blue.
alias: Driveway Motorcycle Notification
description: ''
use_blueprint:
input:
camera: Driveway
notify_device: bc7363883226ffdc36652f57524aff37
labels:
- motorcycle
camera.driveway_motorcycle
contains a snapshot of when the last motorcycle was detected.
Any help appreciated. Thanks in advance.
Case matters. Is your camera in Frigate defined as Driveway
or driveway
cameras:
Driveway:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]/cam/realmonitor?channel=1&subtype=0
roles:
# - rtmp
- clips
- path: rtsp://admin:[email protected]/cam/realmonitor?channel=1&subtype=2
roles:
- detect
width: 1920
height: 1080
fps: 5
objects:
track:
- person
- car
- motorcycle
- truck
- cat
- dog
rtmp:
enabled: False
clips:
enabled: True
pre_capture: 5
post_capture: 5
retain:
default: 3
Edit: Figured it out - canāt have a trailing slash when you enter the Base URL.
Anyone get this working using a Nabu Casa external URL? I added my Nabu Casa URL to the (Optional) Base URL section as such: https://redacted.ui.nabu.casa/
When testing the automation, I just see an error in my HA logs:
Logger: homeassistant.components.automation.notify_person_in_backyard
Source: components/automation/__init__.py:454
Integration: Automation ([documentation](https://www.home-assistant.io/integrations/automation), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+automation%22))
First occurred: 5:41:32 PM (1 occurrences)
Last logged: 5:41:32 PM
Error rendering variables: UndefinedError: 'dict object' has no attribute 'payload_json'
@hunterjm Iām trying to use the Blueprint with Microsoft Teams. I do get the text message but, canāt seem to get the image into the message as well.
According to the Notify help for Teams there should be the option:
title: Title of the message.
message: Message that will be added.
image_url: URL_OF_IMAGE
How should I adjust the template to get this to function
please can you explain better how to and where exactly put code, to have android notification without delay?
with this one, i have delay
blueprint:
name: Frigate Notification
description: "## Frigate Mobile App Notification\n\nThis blueprint will send a notification\
\ to your device when a Frigate event for the selected camera is fired. The notification\
\ will initially include the thumbnail of the detection, but will update to include\
\ actionable notifications allowing you to view the saved clip/snapshot when available,\
\ or silence the notification for a configurable amount of time.\n\nWith this\
\ blueprint, you may send the notification to multiple devices by leaving \"Device\"\
\ blank and instead use a [notification group][1].\n\n### Required entities:\n\
\ - Frigate Camera Name\n - Mobile App Device **or** the name of a Notification\
\ Group\n\n### Optional features:\n - You can limit notifications to objects\
\ entering **any** pre-defined [zones][2] in Frigate.\n - You can specify which\
\ [zones][2] to be notified about. This must be a list (e.g.):\n ```yaml\n\
\ - backyard\n ```\n - You can specify what type of [objects][3] to be\
\ notified about. This must be a list (e.g.):\n ```yaml\n - person\n \
\ - car\n ```\n - You can disable notifications if a presence entity or group\
\ is \"home\".\n - You can configure a cooldown for the camera to reduce the\
\ number of notifications when back-to-back events occur.\n - You can silence\
\ future notifications for a defined amount of time through actionable notifications.\
\ This is helpful in situations where you know you will be triggering detections\
\ for an extended period of time, like when the kids are playing outside.\n\n\
[1]: https://companion.home-assistant.io/docs/notifications/notifications-basic#sending-notifications-to-multiple-devices\n\
[2]: https://blakeblackshear.github.io/frigate/configuration/cameras#zones\n[3]:\
\ https://blakeblackshear.github.io/frigate/configuration/objects\n"
domain: automation
source_url: https://gist.github.com/hunterjm/23c1588a9f2b8b9c2a62ffc364e17f8c
input:
camera:
description: The name of the camera as defined in your frigate configuration.
notify_device:
description: The device must run the official Home Assistant app to receive
notifications.
default: false
selector:
device:
integration: mobile_app
notify_group:
description: The name of the notification group to call.
default: ''
base_url:
name: (Optional) Base URL
description: 'The external url for your Home Assistant instance. This will default
to a relative URL and will open the clips in the app instead of the browser,
which may cause issues on some devices.
default: ''
zone_filter:
name: (Optional) Zone Filter
description: Only notify if object has entered a defined zone.
default: false
selector:
boolean: {}
zones:
name: (Optional) Trigger Zones
description: A list (-) of zones you wish to recieve notifications for.
default: []
selector:
object: {}
labels:
name: (Optional) Trigger Objects
description: A list (-) of objects you wish to recieve notifications for.
default: []
selector:
object: {}
presence_filter:
name: (Optional) Presence Filter
description: Only notify if selected presence entity is not "home".
default: ''
selector:
entity: {}
cooldown:
description: Delay before sending another notification for this camera after
the last event.
default: 30
selector:
number:
max: 300.0
min: 0.0
unit_of_measurement: seconds
mode: slider
step: 1.0
silence_timer:
name: (Optional) Silence Notifications
description: 'How long to silence notifications for this camera when requested
as part of the actionable notification.
default: 30
selector:
number:
max: 300.0
min: 0.0
unit_of_measurement: minutes
mode: slider
step: 1.0
mode: single
max_exceeded: silent
platform: mqtt
topic: frigate/events
payload: !input 'camera'
value_template: '{{ value_json[''after''][''camera''] }}'
variables:
id: '{{ trigger.payload_json[''after''][''id''] }}'
camera: '{{ trigger.payload_json[''after''][''camera''] }}'
camera_name: '{{ camera | replace(''_'', '' '') | title }}'
object: '{{ trigger.payload_json[''after''][''label''] }}'
label: '{{ object | title }}'
entered_zones: '{{ trigger.payload_json[''after''][''entered_zones''] }}'
type: '{{ trigger.payload_json[''type''] }}'
base_url: !input 'base_url'
group_target: !input 'notify_group'
zone_only: !input 'zone_filter'
input_zones: !input 'zones'
zones: '{{ input_zones | list }}'
input_labels: !input 'labels'
labels: '{{ input_labels | list }}'
presence_entity: !input 'presence_filter'
condition:
- '{{ type != ''end'' }}'
- '{{ not zone_only or entered_zones|length > 0 }}'
- '{{ not zones|length or zones|select(''in'', entered_zones)|list|length > 0 }}'
- '{{ not labels|length or object in labels }}'
- '{{ not presence_entity or not is_state(presence_entity, ''home'') }}'
- choose:
- conditions: '{{ not group_target }}'
sequence:
- device_id: !input 'notify_device'
domain: mobile_app
type: notify
message: A {{ label }} was detected on the {{ camera_name }} camera.
tag: '{{ id }}'
group: frigate-notification-{{ camera }}
image: /api/frigate/notifications/{{id}}/thumbnail.jpg?format=android
url: /api/frigate/notifications/{{id}}/thumbnail.jpg
priority: high
ttl: 0
default:
- service: notify.{{ group_target }}
tag: '{{ id }}'
priority: high
ttl: 0
- repeat:
sequence:
- wait_for_trigger:
- platform: mqtt
payload: '{{ id }}'
value_template: '{{ value_json[''after''][''id''] }}'
timeout:
minutes: 2
continue_on_timeout: false
- condition: template
value_template: '{{ wait.trigger.payload_json[''type''] == ''end'' }}'
- choose:
sequence:
domain: mobile_app
type: notify
tag: '{{ id }}'
url: '{{base_url}}/api/frigate/notifications/{{id}}/{{camera}}/clip.mp4'
clickAction: '{{base_url}}/api/frigate/notifications/{{id}}/{{camera}}/clip.mp4'
priority: high
ttl: 0
sound: none
actions:
- action: URI
title: View Clip
uri: '{{base_url}}/api/frigate/notifications/{{id}}/{{camera}}/clip.mp4'
- action: URI
title: View Snapshot
uri: '{{base_url}}/api/frigate/notifications/{{id}}/snapshot.jpg'
- action: silence-{{ camera }}
title: Silence Notifications
destructive: true
default:
tag: '{{ id }}'
priority: high
ttl: 0
sound: none
actions:
- action: URI
title: View Clip
- action: URI
destructive: true
until: '{{ wait.trigger.payload_json[''type''] == ''end'' }}'
- wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
timeout:
seconds: !input 'cooldown'
- delay:
minutes: !input 'silence_timer'
i have the same problem as this, Iām pretty sure the name is correct as well for mine but I might be missing something?
For those looking to get notifications in Teams, see below how I resolved this using NodeRed. Change the āexternalAddressā with the sitename you have. It needs to be accessible from outside to show pictures.
var externalAddress = "https://yourAddress";
msg.payload = {
"type":"message",
"attachments":[
"contentType":"application/vnd.microsoft.card.adaptive",
"contentUrl":null,
"content":{
"$schema":"http://adaptivecards.io/schemas/adaptive-card.json",
"type":"AdaptiveCard",
"version":"1.3",
"body": [
"type": "TextBlock",
"size": "Medium",
"weight": "Bolder",
"text": "Person detected",
"color": "Accent"
"text": "On camera " + msg.payload.after.camera + " at the front door in zone: " + msg.payload.after.entered_zones[0],
"wrap": true
"type": "Image",
"url": externalAddress + "/api/events/"+ msg.payload.after.id +"/thumbnail.jpg",
"actions": [
"type": "Action.OpenUrl",
"title": "View",
"url": externalAddress + "/clips/" + msg.payload.after.camera + "-" + msg.payload.after.id + ".mp4"
Try restarting the add-on or restarting Home Assistantā¦ Or just everything.
My notification just started to work out of the blue and I didnāt make any changes to it.
Just me how need sound for this notification even if the phone is mute?
i have updated and also restarted but seems like its still not working for me. not sure on how to manually add the clip images of what it detected to my notification
