Frigate Mobile App Notifications
This is how mine is set up and it works to send the image MOST of the time but the clips aren’t viewable as I’m using Home Assistant Cloud.
hm the only thing i didnt have was base URL which I have added and still nth. weird, this is what comes from the logs.
Hi @hunterjm, thank you so much for creating this blueprint!
Is it possible to add a motion mask to this blueprint? I was hoping it would use the mask defined in the frigate.yml but it doesn’t seem to. I’m getting notifications every 30s for my car parked in the driveway :slight_smile:
I tried editing the yaml file to manual add it using:
    motion:
      mask:
        - 430,720,752,720,912,582,1038,304,974,231,896,195,704,211,386,428,267,592
near the zones section but it said “Property mask isn’t allowed”?
For some reason I’m not getting the notifications on my device. Is anyone else having an issue?
share your config
doesn’t works this blueprints, if you use Frigate into a docker lxc proxmox
Need to be edit.
You receive notifications, but doesn’t works if you tap on it, and you didn’t have any image from camera.
Which config should I post? just a picture of my settings on the notification?
I appreciate u reaching out!
-Nick
you didn’t have notification because you must share your configuration about automation,maybe you use a wrong name about camera and or your device ( smartphone )
share frigate.yaml and automation
Thanks for your assistance, I found from a post a few weeks ago that when listing trigger objects use a space after the “-” i.e.
  • person
  • dog
  • cat
  • car
Now i know what i need to post next time though! haha
Is it possible to add multiple Silence Times? I fail at adding a second part in the wait_for_trigger. How does this have to be?
Also sometimes (mostly on my watch) the attachment (picture) could not be loaded. Any way to fix this?
My notifications stopped having snapshots/ images visible today. Unsure what might be causing that.
Edit. seemed to be an error in frigate, restarting it resolved the snapshot issue.
So I just updated to v2.0 where clips are merged with recordings. I do not record 24/7 so using the example provided I am only retaining events… but now View Clip from the actionable notification seems to 404 no matter what (previously it was just I clicked it too soon after the event) Did I miss a step to get the clips to visible from the notifications? or is this going to be more difficult/not possible now with the clips being merged with recordings?..
EDIT:
I suppose I realize now the “clip” per say does not exist at all in this new format…. Can I link to the event in frigate UI instead somehow? Like generate a url that would contain the link to the event times… my apologies if I missed something obvious here.
Have you updated both the integration to 2.1.0 (show beta version in HACS) and Frigate to 0.9.1?
Nope… so that’s what I missed. Sorry that’s what I get for trying to update stuff while half asleep. I knew that version v2.0 I read in the changelog didn’t make sense with the v9.1 or whatever I was seeing… it’s because one was referring to the integration and one the add-on… thank you, I’ll try that. My apologies.
EDIT: so that was my issue was not updating the integration as well but I just wanted to also mention that now with this new merged clip/recordings the clips load immediately even if I click on the View Clip notification right away where as previously I had to give it a bit to make sure the clip was available prior to clicking view clip. Awesome work! Thank you for your time and effort.
Since the upgrade… I get the notifications with out the snapshot/image included
I have the 2.10 integration along with the new Frigate Addon update
Hi, thanks a lot for your work, it’s just amazing but could you please add a time condition like the one integrated in home assistant? Thanks.
Anyone else?
All good here… I had initially missed updating the integration itself but even then the snapshots still worked just not the clips… are you seeing the snapshots in the Frigate UI?
Oh good point… ill check if I messed that up
This is a great fix. thx.
