I was using frigate with a Foscam fi9800p.
I recently updated to Frigate 0.11.1 (not sure what version I was on previously)
Unfortunately, my camera stopped working.
My config looks like this:
cameras:
voortuin_camera:
record:
events:
required_zones:
- voortuin
ffmpeg:
inputs:
- path: "rtsp://myUser:[email protected]:554/videoMain"
roles:
- record
- detect
detect:
width: 1280
height: 720
zones:
voortuin:
coordinates: 0,720,1280,720,1280,628,1045,605,834,431,439,494,0,494
motion:
mask:
- 1280,0,0,0,0,626,215,562,342,600,433,659,537,560,427,308,0,374,0,234,1280,67,1280,209,757,254,1050,609,1280,558
detectors:
coral:
type: cpu
mqtt:
host: core-mosquitto
user: mqtt_user
password: mqtt_pass
record:
enabled: true
retain_days: 0
events:
retain:
default: 5
ffmpeg:
hwaccel_args:
- -hwaccel
- qsv
- -qsv_device
- /dev/dri/renderD128
objects:
track:
- person
logger:
default: info
When I open the url rtsp://myUser:[email protected]:554/videoMain with a player like VLC, I can see the camera is working fine.
When I open the frigate log (right after a restart of frigate), I see:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2023-04-01 19:25:25] frigate.app INFO : Starting Frigate (0.11.1-2eada21)
[2023-04-01 19:25:25] frigate.config WARNING : The 'retain_days' config option has been DEPRECATED and will be removed in a future version. Please use the 'days' setting under 'retain'
[2023-04-01 19:25:25] frigate.app INFO : Creating directory: /tmp/cache
Starting migrations
[2023-04-01 19:25:25] peewee_migrate INFO : Starting migrations
There is nothing to migrate
[2023-04-01 19:25:25] peewee_migrate INFO : There is nothing to migrate
[2023-04-01 19:25:25] frigate.app INFO : Output process started: 217
[2023-04-01 19:25:25] ws4py INFO : Using epoll
[2023-04-01 19:25:25] frigate.app INFO : Camera processor started for voortuin_camera: 223
[2023-04-01 19:25:25] frigate.app INFO : Capture process started for voortuin_camera: 226
[2023-04-01 19:25:25] detector.coral INFO : Starting detection process: 216
[2023-04-01 19:25:25] frigate.edgetpu WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
[2023-04-01 19:25:25] frigate.video ERROR : voortuin_camera: Unable to read frames from ffmpeg process.
[2023-04-01 19:25:25] frigate.video ERROR : voortuin_camera: ffmpeg process is not running. exiting capture thread...
[2023-04-01 19:25:27] ws4py INFO : Using epoll
[2023-04-01 19:25:45] watchdog.voortuin_camera ERROR : Ffmpeg process crashed unexpectedly for voortuin_camera.
[2023-04-01 19:25:45] watchdog.voortuin_camera ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
[2023-04-01 19:25:45] ffmpeg.voortuin_camera.detect ERROR : [AVHWDeviceContext @ 0x5633f2d817c0] No VA display found for device /dev/dri/renderD128.
[2023-04-01 19:25:45] ffmpeg.voortuin_camera.detect ERROR : Device creation failed: -22.
[2023-04-01 19:25:45] ffmpeg.voortuin_camera.detect ERROR : Failed to set value '/dev/dri/renderD128' for option 'qsv_device': Invalid argument
[2023-04-01 19:25:45] ffmpeg.voortuin_camera.detect ERROR : Error parsing global options: Invalid argument
[2023-04-01 19:25:45] frigate.video ERROR : voortuin_camera: Unable to read frames from ffmpeg process.
[2023-04-01 19:25:45] frigate.video ERROR : voortuin_camera: ffmpeg process is not running. exiting capture thread...
Any idea what could be the issue?
