Frigate not delivering event trigers
I’m running frigate on an Intel NUC under proxmox in a separate LXC container.
I can not get detecting a person activated. Furthermore, I have tried many things. Hopefully, someone can help and point out what I am missing?
Thanks for your help!
I have the following config.yml file
mqtt:
  host: mqtt://192.168.178.183
  port: 1883
  topic_prefix: frigate
  user: admin
  password: 'password'
  stats_interval: 60
logger:
  default: info
  logs:
    frigate.mqtt: debug
birdseye:
  enabled: True
  mode: continuous
detectors: # <---- add detectors
  coral:
    type: edgetpu
    device: usb
go2rtc:
  streams:
    voordeur:
      - rtsp://admin:[email protected]:554//cam/realmonitor?channel=1&subty>
      #- "ffmpeg:voordeur#audio=opus"
    voordeur_sub:
      - rtsp://admin:[email protected]:554//cam/realmonitor?channel=1&subt>
      #- "ffmpeg:voordeur_sub#audio=opus"
    oprit:
      #- "ffmpeg:oprit#audio=opus"
    oprit_sub:
      #- "ffmpeg:oprit_sub#audio=opus"
    achterdeur:
      #- "ffmpeg:achterdeur#audio=opus"
    achterdeur_sub:
      #- "ffmpeg:achterdeur_sub#audio=opus"
cameras:
  voordeur:
    ffmpeg:
      hwaccel_args: preset-vaapi
      output_args:
        record: preset-record-generic-copy
      inputs:
        - path: rtsp://192.168.178.184:8554/voordeur
          input_args: preset-rtsp-restream
          roles:
            - record
            - detect
        #- path: rtsp://192.168.178.184:8554/voordeur_sub
        #  input_args: preset-rtsp-restream
        #  roles:
        #    - detect
  oprit:
    ffmpeg:
      output_args:
      inputs:
        - path: rtsp://192.168.178.184:8554/oprit
          roles:
            - record
            - detect
        #- path: rtsp://192.168.178.184:8554/oprit_sub
        #  roles:
        #    - detect
    detect:
      width: 1280
      height: 720
    objects:
      track:
        - person
        - dog
        - cat
        - car
  achterdeur:
    ffmpeg:
      output_args:
      inputs:
        - path: rtsp://192.168.178.184:8554/achterdeur
          roles:
            - record
            - detect
        #- path: rtsp://192.168.178.184:8554/achterdeur_sub
        #  roles:
        #    - detect
    detect:
      width: 1280
      height: 720
    objects:
      track:
        - person
        - dog
        - cat
        - car
How do you configure lxc?
Can frigate see coral and intel gpu?
Yes, the Coral USB is working
And intel gpu?
Frigate werkte ook zonder Coral USB
I did recently setup frigate under ubuntu jammy unprotected proxmox lxc container and it wasn’t simple.
Here are my lxc configuration:
arch: amd64
cores: 4
features: fuse=1,mknod=1,mount=cifs,nesting=1
hostname: frigate
memory: 6144
mp0: sata:230/vm-230-disk-0.raw,mp=/opt/frigate/media,size=512G
mp1: local-lvm:vm-230-disk-5,mp=/opt/frigate/storage,backup=1,size=8G
net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=EE:D3:F2:4D:28:69,ip=dhcp,type=veth
onboot: 1
ostype: ubuntu
rootfs: local-lvm:vm-230-disk-3,size=16G
startup: order=20,up=5
swap: 6144
tags: privileged;production
lxc.cgroup2.devices.allow: c 226:0 rwm
lxc.cgroup2.devices.allow: c 226:128 rwm
lxc.cgroup2.devices.allow: c 29:0 rwm
lxc.cgroup2.devices.allow: c 189:* rwm
lxc.cgroup2.devices.allow: a
lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file 0, 0
lxc.mount.entry: /dev/dri dev/dri none bind,optional,create=dir
lxc.mount.entry: /dev/coralptr dev/bus/usb/002/003 none bind,optional,create=file 0, 0
lxc.mount.entry: /dev/coralptr dev/bus/usb/004/003 none bind,optional,create=file 0, 0
lxc.mount.auto: cgroup:rw
lxc.apparmor.profile: unconfined
lxc.cap.drop:
I am running it on Proxmox 8.0.4
Under datacenter also did resource mappings of the coral-usb
arch: amd64
cores: 4
features: nesting=1
hostname: frigate
memory: 102400
net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=22:81:13:9A:8E:D6,type=veth
onboot: 1
ostype: debian
rootfs: local-lvm:vm-103-disk-0,size=64G
swap: 512
lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=fil>
lxc.mount.entry: /dev/bus/usb/002/ dev/bus/usb/002/ none bind,optional,create=dir 0, 0
lxc.mount.entry: /dev/fb0 dev/fb0 none bind,optional,create=file
lxc.cap.drop:
this is incorrect, host should not include mqtt://
Thanks, I changed this. But is not solving the problem of not generation of any motion events.
Not sure if this is required but try adding …
client_id: frigate
To your mqtt section, right under topic_prefix
To make it easier, I set enabled: False to cut out mqtt for a later stage.
Do you see anything wrong with the event detection? person, dog, cat, car
There is my mqtt section of config if this can help:
mqtt:
    host: 10.1.1.20
    user: username
    password: password
    client_id: frigate
Thanks for sharing! do you have ’ ’ around your password phrase?
No, I don’t.
If you suspect on mqtt I sugest to observe with MQTT Explorer.
I disabled MQTT for now. Because events are not detected.
this is because you do not have recording or snapshots enabled, like the docs say one of these has to be enabled for events
Isn’t MQTT a requirement?
edit: I’m wrong. It of course isn’t.
Hi Nicolas,
Where do I add the recording or snapshot enabled? Hopefully, you can help out or point in the direction?
Thanks!
Thanks Guys!
I followed Nicolas tips on recording and snapshots.
Searched the docs of Frigate
Next up is to connect my Proxmox LXC Frigate container first to another LXC container with my MQTT server and another VM with Homeassistant.
Any tips are welcome!
But, thanks for your great support!
