Ive been finding some time to setup frigate, Today was the day. I set everything up and I didnt get anything, Ive been over everything loads of times but its not working, I must have missed something stupid.
mqtt:
host: 192.168.0.241 #Insert the IP address of your Home Assistant
port: 1883 #Leave as default 1883 or change to match the port set in yout MQTT Broker configuration
topic_prefix: frigate
client_id: frigate
user: mqtt-user #Change to match the username set in your MQTT Broker
password: password #Change to match the password set in your MQTT Broker
stats_interval: 60
cameras:
Driveway: #Change this to a name of the camera that makes sense to you
ffmpeg:
output_args:
record: preset-record-generic-audio-aac #Insert this if your camera supports audio output
inputs:
- path: rtsp://admin:[email protected]:554/Streaming/Channels/101/
roles:
- record
- path: rtsp://admin:[email protected]:554/Streaming/Channels/102/
roles:
- detect
detect:
height: 360 #Change this to match the resolution of your detection channel (in this case channel 1)
width: 640 #Change this to match the resolution of your detection channel (in this case channel 1)
fps: 10 #This is the frame rate for detection, between 5-10 fps is sufficient.
record:
enabled: true
retain:
days: 0 #The number of days a recording will be kept for after a motion is detected.
mode: motion
events:
retain:
default: 30 #The event data will be kept for 1 day. After this period, the event data will be automatically deleted.
mode: motion
objects:
track:
- person
- car
version: 0.14
