Frigate notification when object is moving from one zone to other zone?
Hi folks,
I just started with Frigate and integrated it into my HA, so far, it works perfectly.
I also use the automation blueprint form Frigate for notifications, which basically also works, but I do get too much notifications.
I have a cam at my driveway, which is divided into 3 zones: street-facing, middle and frontdoor-facing.
I want a notification if an object is moving from the middle into the frontdoor zone, but not vice-versa (i.e. if I’m levaing the house (frontdoor → middle), I don’t need a push message). If someone not only wakling by the street, rather than entering my driveway and coming to my door/house, I want a push.
I’m sure that is possible, but I couldn’t find out how.
I see the MQTT messages from Frigate, but I couldn’t find any docs, explaining the difference between “before” and “after” section in the JSON. I saw some examples in the internet around, one was using after, one was using befor, but no really sense for me.
Can someone point me in the right directen?
Thanks!!
Before is just the message before the current one that has been sent (which is after). It’s also worth noting that the zones listed in entered_zones are chronological
ok, in that case, I would actually look for the after part in the JSON.
What is the difference between current_zones and entered_zones? I assume current is the one, the object is right now (correlating with the after part) and entered_zones is the histroy?
In my case:
In the before part the object would need to entered_zones == street and middle
And in the after part the current_zone == door
Sounds right to me
@oggy512 will you lmk if you get this working? i’ve struggled to get this working in an automation myself, and it feels like it should be pretty straightforward to do :man_shrugging:
Think I may finally have a working example of this. I’ve only briefly tested this so far, and my use case isnt exactly like yours b/c i only have 2 zones (near/far), but this tracks a person walking from mudroom_far into mudroom_near and logs the output (as an error so its easy to see it happening real time).
- alias: "Frigate: Track Object in Zones"
  id: "Frigate: Track Object in Zones"
    - platform: mqtt
      topic: frigate/events
      payload: mudroom
      value_template: '{{ value_json["after"]["camera"] }}'
      variables:
        after_zones: "{{ trigger.payload_json['after']['entered_zones'] }}"
        label: "{{ trigger.payload_json['after']['label'] }}"
  condition:
    - "{{ label == 'person' }}"
    - "{{ 'mudroom_far' in after_zones }}"
    - service: system_log.write
      data_template:
        message: "LOGGING: first zone"
        level: error
    - wait_for_trigger:
        - platform: mqtt
          value_template: "{{ 'mudroom_near' in wait.trigger.payload_json['after']['current_zones'] }}"
      timeout: "00:00:45"
      continue_on_timeout: false
      data_template:
        message: "LOGGING: second zone"
        level: error
    - delay: 15
Here’s where I’ve landed on this, it’s been working really well for the past ~6days. This uses go2rtc to record a 10s clip once the object moves into the “far away” zone, then, if that object hits the “near zone”, it sends the clip as a notification via telegram.
