Frigate notifications on telegram with picture
I have Frigate and telegram installed with a Camera R4252.
I try to create an automation to notify when something it’s triggered on the camera.
My camera have those sensors :
My automation :
alias: Alarm
description: Alarme
  - platform: state
    entity_id:
      - binary_sensor.detecteur_ouverture_porte_baie_vitree_contact
    to: "on"
  - platform: state
    entity_id:
      - sensor.r4252_smart_outdoor_camera_cat_count
    to: "1"
condition:
  - condition: state
    entity_id: input_boolean.alarm_override
    state: "on"
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.r4252_smart_outdoor_camera_cat_count
            state: "1"
        sequence:
          - service: notify.lilp_bot
            metadata: {}
              message: Un chat a été détecté
              title: Alarm Chat
mode: single
The entity image.r4252_smart_outdoor_camera_cat who can see as 4 entity on picture have those attributes :
access_token: XxX
entity_picture: >-
  /api/image_proxy/image.r4252_smart_outdoor_camera_cat?token=XxX
friendly_name: R4252 Smart Outdoor Camera Cat
The notification is trigged well when the cat entity count change from 0 to 1, and send a message.
But I wish add picture or snapshot of the trigged.
I try to add it by using :
entity_picture: >-
But don’t know how to.
Thanks.
For this it’s recommended to use the frigate notification blueprint
@crzynik the Frigate notification blueprint does not support Telegram AFAIK:
And there is not much movement on the pull requests (last in February 2024):
Is a good one to look at as well
Yes Frigate Notification Blueprint doesn’t support Telegram notification.
Also, I wish add more sensor than frigate. Like my windows sensor and Frigate Notification blueprint don’t allow that.
In Home Assistant 2024.7 you will be able to convert blueprint into an editable automation. You can then replace the notification with Frigate:
It will be a nice new feature.
Still in 2024.6, I’m waiting the official 2024.7 so. :slight_smile:
It should be released today after the release party:
For now, I’m testing a solution like.
3 frigate automations (night, home, away)
With another automations to enable theses by times :
alias: Activation auto alarme nuit
description: Activation auto alarme nuit
  - platform: time
    at: "00:00:00"
  - platform: time
    at: "06:00:00"
condition:
  - condition: state
    entity_id: automation.frigate_away
    state: "off"
  - condition: state
    entity_id: automation.frigate_notifications
    state: "off"
    enabled: false
  - choose:
      - conditions:
          - condition: time
            after: "12:00:00"
            before: "06:00:00"
        sequence:
          - service: automation.toggle
            metadata: {}
            data: {}
              entity_id:
                - automation.frigate_night
                - automation.frigate_notifications
      - conditions:
          - condition: time
            after: "06:00:00"
            before: "12:00:00"
        sequence:
            metadata: {}
            data: {}
              entity_id:
mode: single
And another for better away mode with windows sensor
alias: Alarm
description: Alarme
  - platform: state
    entity_id:
    to: "on"
condition:
  - condition: state
    state: "on"
  - choose:
      - conditions:
          - condition: state
            state: "1"
        sequence:
            metadata: {}
              title: Alarm Chat
            enabled: false
          - service: notify.mobile_app_oneplus
            metadata: {}
              message: Un chat a été détecté dehors
      - conditions:
          - condition: state
            entity_id: sensor.r4252_smart_outdoor_camera_dog_count
            state: "1"
        sequence:
            metadata: {}
              message: Un chien a été détecté
              title: Alarm Chien
            enabled: false
            metadata: {}
              message: Un chien a été détecté dehors
      - conditions:
          - condition: state
            entity_id: sensor.r4252_smart_outdoor_camera_person_count
            state: "1"
        sequence:
            metadata: {}
              message: Une personne a été détecté
              title: Alarm Personn
            enabled: false
            metadata: {}
              message: Une personne a été détecté dehors
It seems you are using the same services to get notified. You should use a script to do so, it will make your automation more readable and then you can adapt your notifications there.
I have this script:
alias: Notify People in the building
sequence:
  - parallel:
      - service: notify.telegramcloom
          title: "*{{ title }}*"
          message: |
            ```b {{ message }}```
      - service: notify.persistent_notification
          title: "{{ title }}"
          message: |
            {{ message }}
      - service: notify.cloomwhatsapp
          message: |
            *{{ title }}*
            {{ message }}
        enabled: false
      - service: notify.anaconciergewhatsapp
          message: |
            *{{ title }}*
            {{ message }}
        enabled: false
      - service: notify.mobile_app_rs_403
          message: "{{ message }}"
        enabled: true
mode: single
icon: mdi:message-badge-outline
There are some disabled because Whatsapp messages are not free anymore. You can use come up with something if you don’t want to notify all the services in your script.
Then I call this script from automations:
service: script.notify_sbs_lofts
  title: "Problem detected on {{ trigger.from_state.attributes.friendly_name }}"
  message: >
    {{"\n"}}ECS: {{ states('sensor.sonde_ecs') }} {{"\n"}}Retour coge circuit
    chauffage: {{ states('sensor.sonde_retour_coge_circuit_chauffage') }}
    {{"\n"}}Retour Cogénération: {{ states('sensor.retour_cogeneration') }}
    {{"\n"}}Cogénération en défaut: {{ "YES!!!" if
    states('binary_sensor.i7_default_coge') == "on" else "NO" }}
Don’t really understand your tips.
I create a script
alias: Notify
sequence:
  - parallel:
          message: |
          message: |
            {{ message }}
mode: single
Then an automation :
alias: Test notification
description: ""
trigger: []
condition: []
  - service: script.test
    metadata: {}
      title: Problem detected on {{ trigger.from_state.attributes.friendly_name }}
      message: >
        circuit chauffage: {{
        states('sensor.sonde_retour_coge_circuit_chauffage') }} {{"\n"}}Retour
mode: single
But when I run the automation nothing happen.
It’s normal, you re-used my sensors in the message.
Create a script that is taking 2 arguments: title and message
alias: Notify
sequence:
  - parallel:
mode: single
[/quote]
Then you can use the developer tools and call the script:
service: script.notify_script_name
  title: "Test"
  message: "Ne rien faire"
Then if you have a sensor living_room_temperature you can put it in the message:
  title: "Too Hot!"
  message: "Living room is burning hot, temperature is {{ states('sensor.living_room_temperature') }} degrees!"
For automation templates you can look at the official documentation:
I make the changes
Script
alias: Notify
sequence:
  - parallel:
          message: |
          message: |
            {{ message }}
mode: single
description: Script Notify
The automation
alias: Alarm
description: Alarme
  - platform: state
    entity_id:
    to: "on"
condition:
  - condition: state
    state: "on"
  - choose:
      - conditions:
          - condition: state
            state: "1"
        sequence:
          - service: script.notify
              title: Mouvement détecté
              message: >
                {{"\n"}}Mouvement détecté: {{
                states('sensor.r4252_smart_outdoor_camera_cat_count') }}
                personne détectée.
      - conditions:
          - condition: state
            state: "1"
        sequence:
              message: >
                personne détectée.
      - conditions:
          - condition: state
            state: "1"
        sequence:
            metadata: {}
              message: >
                personne détectée.
              message: >
                personne détectée.
