I have performed a search and haven’t found a thread on-topic.
I am a long time user of the Frigate NVR add on and have used it for quite a few months with no problems.
Recently, however, my Frigate NVR has been crashing the HA supervisor. HA restarts and will quickly end up restarting again. I know it is related to Frigate because when I disable the add on, the behavior goes away (as well as hints in the log files). Nothing changed in my configuration (except for updates to HA and the HA operating system). I run the HA OS in a VM on a TrueNas server.
Is anyone else experiencing this issue? And, if so, did it just recently begin?
Here is the entry:
“2022-08-10 08:36:51.547 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant”
Here is what is reported about Frigate in the Supervisor logs - I doubt this is the problem:
22-08-11 21:02:08 WARNING (SyncWorker_2) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR (Full Access)
22-08-11 21:02:08 WARNING (SyncWorker_4) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR (Full Access)
The ADDON Log is full of the following:
[2022-08-11 22:55:54] ffmpeg.garage.detect ERROR : [segment @ 0x55d80111ce00] Non-monotonous DTS in output stream 0:0; previous: 214292, current: -318940; changing to 214293. This may result in incorrect timestamps in the output file.
[2022-08-11 22:55:54] ffmpeg.garage.detect ERROR : [flv @ 0x55d801128b40] Non-monotonous DTS in output stream 1:0; previous: 13939, current: -20764; changing to 13939. This may result in incorrect timestamps in the output file.
[2022-08-11 22:55:54] ffmpeg.garage.detect ERROR : [segment @ 0x55d80111ce00] Non-monotonous DTS in output stream 0:0; previous: 214293, current: -317916; changing to 214294. This may result in incorrect timestamps in the output file.
What changes did you make on frigate.yaml? I am having same problem as well. Whenever I open frigate or someone passes from the camera the system freeze and I have to pull the plug and make it restart.
Hello can you please explain what may have been the difference in your config.yml? Or are you saying all the configs were the same but the file was in fact just corrupted for some odd reason? I am having this issue ever since I got frigate up and running. I am using a coral accelerator connected to a powered usb. The powered usb is then connected to the usb 3.0 on the pi4.
I’m having this issue now. I’ve deleted the yaml and rewrote it from scratch, but this didn’t help. HA restarts a few times a day, unless I disable Frigate. Very annoying!
