Hi all, I have a new PC that runs HASSIO . Previously, I was using a PC with a USB Coral for some time. Now, I’ve moved to a newer PC with a PCIe slot, where I’ve installed a Coral. However, I still have a USB Coral sitting idle. Is it worth running both types of Coral on the same machine?
if you have enough cameras and activity to cause skipped frames then yes, otherwise it won’t make a difference but increase power usage
Thanks for that
