I used a timer from Devices & Services > Helpers that is triggered by the “motion on” script, and then the timer triggers the turn off script. The timer default value sets the light’s on time.
I’m using Frigate proxy, but acting on MQTT messages. You can see the name of my camera “front_door” in the value_template config.
I check that it’s dark outside, and that the light if currently off. That way it doesn’t turn off a light that was turned on by a user. Ideally I would track “on by motion” and extend or reset the timer.
The on script:
alias: Outside Light Motion On
description: ''
- platform: mqtt
topic: frigate/events
payload: 'on'
value_template: >-
{{ "on" if value_json["type"] == "new" and value_json["before"]["camera"]
== "front_door" and value_json["before"]["label"] == "person" else "off"}}
condition:
- condition: device
type: is_off
device_id: bb31e928e8d8bf41f26afec557d3c5b6
entity_id: light.outside_light
domain: light
- condition: state
entity_id: sun.sun
state: below_horizon
- type: turn_on
domain: light
brightness_pct: 100
- service: timer.start
entity_id: timer.outside_light_motion_on
data: {}
mode: single
The off script:
alias: Outside Light Motion Off
description: ''
- platform: event
event_type: timer.finished
event_data:
condition: []
- type: turn_off
domain: light
mode: single
