Hi Guys,
I’m struggling to understand why I cannot get my Frigate NVR setup to record any video. I have had this working in the past. but now for some reason it’s stopped working and says I don’t have recording enabled!! I’m using an Annke C800 camera. When I go into the recordings it simply says
No Recordings Found
Make sure you have enabled the record role in your configuration for the front camera.
I’m using the following code in my friagte.yaml file
mqtt:
host: 192.168.0.149
port: 1883
topic_prefix: frigate
client_id: frigate
user: mqtt
password: landy90
stats_interval: 60
detectors:
coral:
type: edgetpu
device: usb
cameras:
front:
ffmpeg:
inputs:
- path: rtsp://mattpitts74:[email protected]:554/Streaming/Channels/102?transportmode=mcast&profile=Profile_2
roles:
- detect
- rtmp
- path: rtsp://mattpitts74:[email protected]:554/Streaming/Channels/102?transportmode=mcast&profile=Profile_1
roles:
- record
detect:
width: 640
height: 480
fps: 5
record:
enabled: true
objects:
track:
- person
snapshots:
enabled: true
motion:
mask:
- 0,480,65,480,68,425,59,374,49,324,44,276,53,241,68,191,110,169,140,147,173,124,197,101,240,81,313,87,408,88,443,63,467,0,403,0,0,0
I have the record role set for the higher resolution stream, but it’s not recording anything!! I cannot for the life of me figure out why it’s not recording!!
Any help would be much appreciated.
