Frigate NVR
Hi , how do i fix the following log errors , i have tried contact the builder of the Frigate NVR addon with out success . I have also read may article which had ti think the same problem.
21-04-07 09:13:14 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on ccab4aaf/amd64-addon-frigate with version 1.13 21-04-07 09:13:14 WARNING (MainThread) [supervisor.addons.addon] ccab4aaf_frigate is already running! 21-04-07 09:13:19 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled 21-04-07 09:13:19 INFO (MainThread) [supervisor.core] Supervisor is up and running 21-04-07 09:13:19 INFO (MainThread) [supervisor.host.info] Updating local host information 21-04-07 09:13:19 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.check] System checks complete 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING 21-04-07 09:13:19 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete 21-04-07 09:13:19 INFO (MainThread) [supervisor.host.services] Updating service information 21-04-07 09:13:20 INFO (MainThread) [supervisor.host.network] Updating local network information 21-04-07 09:13:21 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information 21-04-07 09:13:21 INFO (MainThread) [supervisor.host] Host information reload completed 21-04-07 09:13:36 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.5:5000 ssl:default [Connect call failed ('172.30.33.5', 5000)] 21-04-07 09:13:36 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize 21-04-07 09:13:36 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered 21-04-07 09:13:36 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running text
The Frigate NVR addon will not run
