Frigate on intel N100
Good afternoon.
Has anyone managed to run Frigate normally on an Intel N100 processor
I have a Beeline mini PC with this processor and a HassOS system.
I can’t figure out the Frigate settings, namely
ffmpeg:
hwaccel_args:
There is a feeling that this processor does not have render.
Thanks.
Errors:
I waited a bit and got an error from the accelerator:
2023-04-11 14:55:02.634208631 [2023-04-11 22:55:02] [frigate.video](https://frigate.video/) ERROR : cam_1: Unable to read frames from ffmpeg process.
2023-04-11 14:55:02.634588133 [2023-04-11 22:55:02] [frigate.video](https://frigate.video/) ERROR : cam_1: ffmpeg process is not running. exiting capture thread...
2023-04-11 14:55:05.478806093 [2023-04-11 22:55:05] frigate.util ERROR : Unable to poll intel GPU stats: No device filter specified and no discrete/integrated i915 devices found
2023-04-11 14:55:09.266620115 [INFO] Starting go2rtc healthcheck service...
2023-04-11 14:55:20.366241795 [2023-04-11 22:55:20] watchdog.cam_kalitka ERROR : Ffmpeg process crashed unexpectedly for cam_kalitka.
2023-04-11 14:55:20.366571933 [2023-04-11 22:55:20] watchdog.cam_kalitka ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-04-11 14:55:20.367170572 [2023-04-11 22:55:20] ffmpeg.cam_1.detect ERROR : Guessed Channel Layout for Input Stream #0.1 : mono
2023-04-11 14:55:20.367203098 [2023-04-11 22:55:20] ffmpeg.cam_1.detect ERROR : Option hwaccel (use HW accelerated decoding) cannot be applied to output url vaapi -- you are trying to apply an input option to an output file or vice versa. Move this option before the file it belongs to.
2023-04-11 14:55:20.367250338 [2023-04-11 22:55:20] ffmpeg.cam_1.detect ERROR : Error parsing options for output file vaapi.
2023-04-11 14:55:20.367493996 [2023-04-11 22:55:20] ffmpeg.cam_1.detect ERROR : Error opening output files: Invalid argument
2023-04-11 14:55:22.620891817 [2023-04-11 22:55:22] [frigate.video](https://frigate.video/) ERROR : cam_1: Unable to read frames from ffmpeg process.
2023-04-11 14:55:22.622328450 [2023-04-11 22:55:22] [frigate.video](https://frigate.video/) ERROR : cam_1: ffmpeg process is not running. exiting capture thread...
my config:
mqtt:
  host: core-mosquitto
  user: mqtt
  password: mqttpsw
ffmpeg:
  hwaccel_args: preset-vaapi
detectors:
  ov:
    type: openvino
    device: AUTO
    model:
      path: /openvino-model/ssdlite_mobilenet_v2.xml
model:
  width: 300
  height: 300
  input_tensor: nhwc
  input_pixel_format: bgr
  labelmap_path: /openvino-model/coco_91cl_bkgr.txt
go2rtc:
  streams:
    rtsp_cam_1:
      - rtsp://10.10.0.49:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream
      - "ffmpeg:rtsp_cam_1#video=h264"
cameras:
  cam_1:
    ffmpeg:
      inputs:
        - path: rtsp://10.10.0.49:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream
          roles:
            - detect
    detect:
      width: 768
      height: 432
      fps: 3
    objects:
      track:
        - person
        - cat
        - dog
        - car
    motion:
      mask:
        - 768,0,619,0,627,54,627,155,615,262,598,392,586,432,768,432
    live:
      stream_name: rtsp_cam_1
I guess it is quite new still, maybe support will get there, eventually.
I am looking for new HW to run HA on, and the Beelink with N100 caught my interest. But Frigate is still a dealbreaker, it must work
I’m curious; have you guys had luck running Frigate on the N100 yet?
Yes everything works fine for several months
I got the same errors as you on top of this thread.
I am running the N100 on proxmox
How did you mange to solve it?
I recently installed Frigate on HAOS+ Proxmox and I have the same error. Have you solved the problem?
Any update on this one? Same config here: Proxmox, HAOS (VM), Frigate as HACS integration running on NUC N100
Have you guys tried to run Frigate separately from HA creating a dedicated Proxmox LXC container for frigate? The installation is very easy using tteck’s script which can be found here: https://helper-scripts.com/scripts?id=Frigate
After doing that you can add the frigate custom component via HACS which connects HA to Frigate running in the LXC.
Personally I have frigate running in a docker container on a separate Debian 12 host also connected to HA using the custom component. I have not tried the LXC on Proxmox yet because it is not recommended. Still there are installations on Proxmox that seem to run fine.
Got it running. HAOS as VM, Frigate as Addon w. HACS.
I did one mistake, I forget to paththrough the GPU (Proxmox GUI, Hardware. add PCI Device, select GPU). With the additional config above everything is running well.
I have HA on proxmox as VM. And I added the Frigate to HA. I try to add PCI and GPU.
Any of options to configure HW decoding don’t work for me.
I tried all option listen in documentation Hardware Acceleration | Frigate
