I can’t understand how to fix it
any ideas?
Are you running frigate anywhere? Looks like the integration and addon are failing to find an instance of frigate
you need to update the integration
how? I don’t see anything new that this
that is the proxy, I am talking about the integration
I’m running Frigate on another box, so I don’t use the integration but only the proxy add-on
That’s impossible, the logs you supplied above are directly from the integration
Sorry, you are right. my bad and my fault. I didn’t remember that I installed the integration manually. thank you. I made the update and now it works
