Have spent a few days trying to set up the Amcrest ASH-41 PTZ controls in HA with Frigate and not getting too far.
Installed Frigate, MQTT and ONVIF integrations and also tried just using the Amcrest integration.
Coral USB TPU is incompatible with QNAP VMs which is a bummer but this is just a single camera, only used passively so hoping I can get by. I assume though, this also means any HW acceleration is out of the picture.
I can get the RTSP stream showing just fine in lovelace and Frigate doesn’t appear to be constraining the NAS CPU too much when monitoring the Add-On.
I’m guessing there’s something wrong with the ONVIF portion of the frigate.yaml file or ONVIF setup but not sure where I’m off…
Any tips for getting PTZ working with Amcrest ASH-41? Looking more like I’m stuck using the ancient Amcrest android app for now.
Setup:
Latest HA OS running on a QNAP NAS VM - 2GB RAM, 2 CPUs
frigate.yaml
mqtt:
host: 192.168.1.143
user: frigateMQTT
password: password
cameras:
b_camera:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0&authbasic=64
onvif:
host: 192.168.1.109
port: 8000
user: admin
password: password
Frigate ONVIF error:
frigate.ptz.onvif ERROR : Onvif connection to b_camera failed: Unknown error: HTTPConnectionPool(host='192.168.1.109', port=8000): Max retries exceeded with url: /onvif/device_service (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9357c40df0>: Failed to establish a new connection: [Errno 111] Connection refused'))
Rest of Frigate Logs:
2024-07-27 23:19:01.462738944 [2024-07-27 18:19:01] frigate.app INFO : Starting Frigate (0.13.2-6476f8a)
2024-07-27 23:19:01.470249774 [2024-07-27 18:19:01] frigate.app INFO : Creating directory: /tmp/cache
2024-07-27 23:19:02.487847368 2024/07/27 18:19:02 [error] 157#157: *44 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", upstream: "http://127.0.0.1:5001version", host: "127.0.0.1:5000"
2024-07-27 23:19:03.710455611 2024/07/27 18:19:03 [error] 157#157: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "ccab4aaf-frigate:5000"
2024-07-27 23:19:07.957287076 2024/07/27 18:19:07 [error] 157#157: *47 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", upstream: "http://127.0.0.1:5001version", host: "127.0.0.1:5000"
2024-07-27 23:19:08.396287429 [2024-07-27 18:19:08] peewee_migrate.logs INFO : Starting migrations
2024-07-27 23:19:08.707585380 [2024-07-27 18:19:08] peewee_migrate.logs INFO : There is nothing to migrate
2024-07-27 23:19:08.711086973 2024/07/27 18:19:08 [error] 157#157: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "ccab4aaf-frigate:5000"
2024-07-27 23:19:11.185626951 2024/07/27 18:19:11 [error] 157#157: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/events?cameras=b_camera&limit=50&include_thumbnails=0 HTTP/1.1", upstream: "http://127.0.0.1:5001/events?cameras=b_camera&limit=50&include_thumbnails=0", host: "ccab4aaf-frigate:5000"
2024-07-27 23:19:11.187964849 172.30.32.1 - - [27/Jul/2024:18:19:11 -0500] "GET /api/events?cameras=b_camera&limit=50&include_thumbnails=0 HTTP/1.1" 502 157 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
2024-07-27 23:19:12.682501855 [2024-07-27 18:19:12] frigate.ptz.onvif ERROR : Onvif connection to b_camera failed: Unknown error: HTTPConnectionPool(host='192.168.1.109', port=8000): Max retries exceeded with url: /onvif/device_service (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9357c40df0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2024-07-27 23:19:12.714232987 [2024-07-27 18:19:12] frigate.app INFO : Recording process started: 347
2024-07-27 23:19:12.772244368 [2024-07-27 18:19:12] frigate.app INFO : go2rtc process pid: 87
2024-07-27 23:19:13.810248184 2024/07/27 18:19:13 [error] 157#157: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "ccab4aaf-frigate:5000"
2024-07-27 23:19:15.580465046 2024/07/27 18:19:15 [error] 157#157: *52 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", upstream: "http://127.0.0.1:5001version", host: "127.0.0.1:5000"
2024-07-27 23:19:16.603977429 [2024-07-27 18:19:16] frigate.app INFO : Output process started: 367
2024-07-27 23:19:16.621285966 [2024-07-27 18:19:16] detector.cpu INFO : Starting detection process: 365
2024-07-27 23:19:17.061854179 [2024-07-27 18:19:17] frigate.detectors WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
2024-07-27 23:19:18.554832487 [2024-07-27 18:19:17] frigate.app INFO : Camera processor started for b_camera: 373
2024-07-27 23:19:18.560993110 [2024-07-27 18:19:18] frigate.app INFO : Capture process started for b_camera: 375
2024-07-27 23:19:18.737763003 2024/07/27 18:19:18 [error] 157#157: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "ccab4aaf-frigate:5000"
2024-07-27 23:19:23.593433114 2024/07/27 18:19:23 [error] 157#157: *55 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", upstream: "http://127.0.0.1:5001version", host: "127.0.0.1:5000"
2024-07-27 23:19:23.711088452 2024/07/27 18:19:23 [error] 157#157: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "ccab4aaf-frigate:5000"
2024-07-27 23:19:43.282222512 172.30.32.1 - - [27/Jul/2024:18:19:43 -0500] "GET /api/events?cameras=b_camera&limit=50&include_thumbnails=0 HTTP/1.1" 200 3 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
2024-07-27 23:19:45.355262116 172.30.32.1 - - [27/Jul/2024:18:19:45 -0500] "GET /api/b_camera/latest.jpg HTTP/1.1" 499 0 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
2024-07-27 23:19:45.433982754 172.30.32.1 - - [27/Jul/2024:18:19:45 -0500] "GET /api/b_camera/latest.jpg HTTP/1.1" 200 92710 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
2024-07-27 23:19:45.441241439 172.30.32.1 - - [27/Jul/2024:18:19:45 -0500] "GET /api/b_camera/latest.jpg HTTP/1.1" 200 92710 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
2024-07-27 23:19:47.414695814 172.30.32.1 - - [27/Jul/2024:18:19:47 -0500] "GET /api/b_camera/latest.jpg HTTP/1.1" 499 0 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
2024-07-27 23:19:55.361992236 172.30.32.1 - - [27/Jul/2024:18:19:55 -0500] "GET /api/b_camera/latest.jpg HTTP/1.1" 499 0 "-" "HomeAssistant/2024.7.3 aiohttp/3.9.5 Python/3.12" "-"
