How do I stop this?
Hello…
Depending on what you already co figured in your yaml, you can determine the % it needs to be sure that it is the object your aming for…
I set mine to do nothing below 75% accuracy and get little false alarms
Right, I keep forgetting that everything is controlled in your config file. I’m coming from Blue Iris where the toggles and switches were endless.
Thanks!
another option besides increasing the score would be to set a min_area filter on person
Thanks, I’ll read up on that.
