I have HA set up and running on my Intel NUC in a Proxmox VM. I also have Frigate installed and running with my one Amcrest POE camera showing on a Lovelace card on my HA dashboard. My question is how do I get Frigate to recognize objects in my driveway? Is that some coding I need to add to frigate.yml file in config.yml? I’ve been following this tutorial, mostly, but seem to be lost when it comes to setting up the actual detection of movement.
Eventually I want to move Frigate to a Proxmox container along with a Google Coral but I first need to make sure all is working in a basic setup right?
Camera defined like above should enable object detection on low res stream of camera. Low Res is recommended since portion of video with object is reduced to 300x300 and HD only eats for cpu for this but doesn’t improve detection. This depends on object size in video but mostly low res works just as good
I think new beta frigate config is a little diffent
Sorry. I forgot you must add more to get the recording. Detections show as events. There may be additional config for the snapshots but it explained at link provided belowi believe
You’ve been a great help. I’ve made those changes and will review the docs. We don’t get a lot of traffic so I’ll give it some time or go dance in front of the camera.
