Frigate question- what determines the placement of cameras on the camera tab?
What determines the placement of cameras on the camera tab? I would like for the Driveway and Porch cameras to be on the first row, but I can’t see where this is set. Or is it just random?
They are alphabetical order unless you as the user insert a manual order in the configuration via the
ui:
  order: x
config
Thanks, that did the trick.
Having trouble trying to do this to reorder cameras in the UI of 0.14.
I see it in the full config on this site: Full Reference Config | Frigate
however I get an error when trying it with more than one camera and can’t continue to edit the config as the errors cover the entire area save for one line.
Do you start the counting with zero or one? And should ui: be four spaces in from left?
It looks to me in reference config that you have cameras: all the way to the left, then two spaces in is name of cam, then two more spaces is where ui: should be, but I can’t get it working. Is that right?
Thanks for any help on the matter.
Doesn’t matter, it just sorts them relatively.
That’s right, would be best if a screenshot with the error is shown.
Guess i don’t understand how you order the cameras. it tells me it expects an integer. Does anyone have an example of how it should look besides the default ?
