Hello all,
So i been confused with this issue ever since I migrated to a new HAOS VM. I have 1 camera recording without any issues. I upgraded to the new frigate thinking that may have been the problem, but I am having the same issue.
1 thing I notice is that my Frigate Integration fails to setup.
I add this link at the integration entries:
http://ccab4aaf-frigate:5000
Current version: 0.12.1
The weird thing about this is the camera It shows the live and debug view, and I can take snapshots of all my config settings I have setup. Just the recordings do not work.
I can use the RTSP stream in VLC and it works fineā¦
With the Integration off It cant find any of my entities.
Here is my Error Log
2023-07-16 22:40:01.721340956 [2023-07-16 17:40:01] watchdog.backyard_deck ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-07-16 22:40:01.721345574 [2023-07-16 17:40:01] ffmpeg.backyard_deck.detect ERROR : [tcp @ 0x55fffe247140] Connection to tcp://10.0.0.14:554?timeout=5000000 failed: Connection timed out
2023-07-16 22:40:01.721346760 [2023-07-16 17:40:01] ffmpeg.backyard_deck.detect ERROR : rtsp://*:*@10.0.0.14:554/11: Connection timed out
2023-07-16 22:40:06.759953098 [2023-07-16 17:40:06] frigate.video ERROR : backyard_deck: Unable to read frames from ffmpeg process.
2023-07-16 22:40:06.760751385 [2023-07-16 17:40:06] frigate.video ERROR : backyard_deck: ffmpeg process is not running. exiting capture thread...
2023-07-16 22:40:07.875888390 172.30.32.2 - - [16/Jul/2023:17:40:07 -0500] "GET / HTTP/1.1" 200 6641 "-" "HomeAssistantSupervisor/2023.07.1 aiohttp/3.8.4 Python/3.11" "-"
2023-07-16 22:40:11.738045900 [2023-07-16 17:40:11] watchdog.backyard_deck ERROR : Ffmpeg process crashed unexpectedly for backyard_deck.
2023-07-16 22:40:11.738049688 [2023-07-16 17:40:11] watchdog.backyard_deck ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-07-16 22:40:11.738050559 [2023-07-16 17:40:11] ffmpeg.backyard_deck.detect ERROR : [tcp @ 0x5643aab25140] Connection to tcp://10.0.0.14:554?timeout=5000000 failed: Connection timed out
2023-07-16 22:40:11.738051227 [2023-07-16 17:40:11] ffmpeg.backyard_deck.detect ERROR : rtsp://*:*@10.0.0.14:554/11: Connection timed out
2023-07-16 22:40:16.777647700 [2023-07-16 17:40:16] frigate.video ERROR : backyard_deck: Unable to read frames from ffmpeg process.
2023-07-16 22:40:16.778269866 [2023-07-16 17:40:16] frigate.video ERROR : backyard_deck: ffmpeg process is not running. exiting capture thread...
2023-07-16 22:40:21.746930939 [2023-07-16 17:40:21] watchdog.backyard_deck ERROR : Ffmpeg process crashed unexpectedly for backyard_deck.
2023-07-16 22:40:21.747141987 [2023-07-16 17:40:21] watchdog.backyard_deck ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-07-16 22:40:21.747143840 [2023-07-16 17:40:21] ffmpeg.backyard_deck.detect ERROR : [tcp @ 0x55bb09d03140] Connection to tcp://10.0.0.14:554?timeout=5000000 failed: Connection timed out
2023-07-16 22:40:21.747144639 [2023-07-16 17:40:21] ffmpeg.backyard_deck.detect ERROR : rtsp://*:*@10.0.0.14:554/11: Connection timed out
2023-07-16 22:42:07.878908897 172.30.32.2 - - [16/Jul/2023:17:42:07 -0500] "GET / HTTP/1.1" 200 6641 "-" "HomeAssistantSupervisor/2023.07.1 aiohttp/3.8.4 Python/3.11" "-"
2023-07-16 22:44:07.891594340 172.30.32.2 - - [16/Jul/2023:17:44:07 -0500] "GET / HTTP/1.1" 200 6641 "-" "HomeAssistantSupervisor/2023.07.1 aiohttp/3.8.4 Python/3.11" "-"
2023-07-16 22:46:07.889067664 172.30.32.2 - - [16/Jul/2023:17:46:07 -0500] "GET / HTTP/1.1" 200 6641 "-" "HomeAssistantSupervisor/2023.07.1 aiohttp/3.8.4 Python/3.11" "-"
2023-07-16 22:47:30.723777519 [2023-07-16 17:47:30] frigate.video ERROR : backyard_deck: Unable to read frames from ffmpeg process.
2023-07-16 22:47:30.724684155 [2023-07-16 17:47:30] frigate.video ERROR : backyard_deck: ffmpeg process is not running. exiting capture thread...
2023-07-16 22:47:31.778939335 [2023-07-16 17:47:31] watchdog.backyard_deck ERROR : Ffmpeg process crashed unexpectedly for backyard_deck.
2023-07-16 22:47:31.778941658 [2023-07-16 17:47:31] watchdog.backyard_deck ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-07-16 22:47:31.778942410 [2023-07-16 17:47:31] ffmpeg.backyard_deck.detect ERROR : rtsp://*:*@10.0.0.14:554/11: Connection timed out
2023-07-16 22:47:31.778943034 [2023-07-16 17:47:31] ffmpeg.backyard_deck.detect ERROR : Last message repeated 1 times
frigate.yml of the camera
cameras:
backyard_deck:
ffmpeg:
inputs:
# /11 High Resolution Stream
- path: rtsp://10.0.0.14:554/11
roles:
- record
# - detect
# - rtmp
# /12 Low Resolution Stream
- path: rtsp://user:password10.0.0.14:554/11
roles:
- detect
- rtmp
objects:
track:
- person
- car
- dog
filters:
person:
mask:
- 259,309,340,246
