Hi.
With HA Core 2023.6 it’s possible to mount a NAS to Homeassistant.
How can I tell Frigate to store the recordings into the newly mounted network storage?
Thanks in advance
Hi.
Thanks in advance
You need to update the location of the frigate database to be /config/frigate.db (and move it to that location). Then you can create a media share with the name frigate
I changed the db location:
database:
path: /media/networkshare/frigate.db
Then when I launch frigate it stops immediately because the “frigate database is locked”.
I consider myself a newbie to frigate.
Can you walk me through the required configuration?
Is there a way to let the frigate database local and choose recordings to a network share? How can I configure it at frigate.yml ?
Warm regards.
Like I said, it needs to be in the config directory not on the share. Check the docs Advanced Options | Frigate
