I am running Frigate on Raspberry Pi 4 with CPU detector.
The stats show that FFmpeg even uses more CPU than the detection.
Is it normal? I remember that hardware acceleration can be used for FFmpeg?
Setup
- Add-on: Frigate (Full Access)
- Camera: WebRTC camera via source type Hass
- Frigate config (with bundled go2rtc):
mqtt:
enabled: True
birdseye:
enabled: False
ffmpeg:
hwaccel_args:
- -c:v:1
- h264_v4l2m2m
output_args:
record: -f segment -segment_time 10 -segment_format mp4 -use_wallclock_as_timestamps 1 -strftime 1 -c:v copy -c:a copy
rtmp: -c:v copy -c:a copy -f flv
rtmp:
enabled: False
detect:
width: 1920
height: 1080
fps: 5
objects:
track:
- person
record:
enabled: True
retain:
days: 0
events:
pre_capture: 5
post_capture: 5
objects:
- person
required_zones:
- driveway
snapshots:
enabled: True
timestamp: True
required_zones:
- driveway
go2rtc:
streams:
camera.garage_camera:
- hass://supervisor?entity_id=camera.garage_camera
- "ffmpeg:camera.garage_camera#audio=aac"
cameras:
garage_camera:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/camera.garage_camera?video=copy&audio=aac
roles:
- detect
- record
- rtmp
zones:
driveway:
coordinates: ...
