Frigate - Send notfications to email & matrix
Hello hellooo!
I’ve started just recently with HA and Node RED.
I’m trying to get the automations to work via yaml first, and then integrate them into node red. I prefer the node red because of the visual aspect, but I’m still learning both. I got the yaml configuration somewhere here from the forum.
I need a little help with the following to implement this in node red:
alias: Frigate - Notification email
description: ""
  - platform: mqtt
    topic: frigate/events
condition:
  - condition: template
    value_template: "{{ trigger.payload_json[\"type\"] == \"end\" }}"
  - service: notify.email_notify
      title: "Camera {{trigger.payload_json['after']['camera']}}: Motion!"
      message: >-
        Detected object {{trigger.payload_json['after']['label']}} by camera
        {{trigger.payload_json['after']['camera']}}.
        images:
            /media/frigate/clips/{{trigger.payload_json['after']['camera']}}-{{trigger.payload_json['after']['id']}}.jpg
        html: >
          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
          "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
              <html lang="en" xmlns="http://www.w3.org/1999/xhtml">
                  <head>
                      <meta charset="UTF-8">
                      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
                      <meta name="viewport" content="width=device-width, initial-scale=1.0">
                      <title>Intruder alert</title>
                  </head>
                  <body>
                    <div>
                        <div>
                            <h5>Motion detected by camera: <b>{{trigger.payload_json['after']['camera']}}</b></h5>
                        </div>
                        <div>
                          Picture<br><img style="width: 100%; "alt="snapshot1" src="cid:{{trigger.payload_json['after']['camera']}}-{{trigger.payload_json['after']['id']}}.jpg" />
                          <br>
                          Object: {{trigger.payload_json["after"]["label"]}}
                          <br>
                          Time: '{{trigger.payload_json["after"]["start_time"]|int}}'
                        </div>
                        <div>
                          <p>
                            <h5>Links</h5>
                            <ul>
                              <li><a href="http://192.168.50.247:8123/api/frigate/notifications/{{trigger.payload_json['after']['id']}}/snapshot.jpg">Link to Snapshot</a></li>
                              <li><a href="http://192.168.50.247:8123/lovelace/cameras">Home Assistant Cameras</a></li>
                              <li><a href="http://192.168.50.247:8123/media-browser/browser/app%2Cmedia-source%3A%2F%2Ffrigate">Home Assistant Media Browser</a></li>
                            </ul>
                          </p>
                        </div>
                    </div>
                  </body>
              </html>
  - service: notify.matrix_notify
      message: >-
        images:
I have trouble with the condition and html output for emails. Is it even possible to use html in node red? The rest works.
I would also like to attach the records to the email and send them also to Matrix if possible. The path to the records is /media/frigate/recordings/2022-12/16/15/Camera1/26.16.mp4 which is basically /media/frigate/recordings/year-month/day/hour/Camera1/minutes.seconds.mp4.
Anyone out there who can help me?
Thanks!
have a look at
That seems to have everything you need.
…btw. if you managed to verify the session with homeassistant, let me know :wink:
cheers
Daniel
