Frigate starting but crashing
Hi there,
i had it working. activated a record for one more cam, snapshots/detrect was working fine for that cam… since then i have this in the log and frigate crashes.
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service certsync-log: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service frigate-log successfully started
s6-rc: info: service certsync-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
2024-11-27 07:45:42.715282060  [INFO] Preparing Frigate...
2024-11-27 07:45:42.718563612  [INFO] Preparing new go2rtc config...
2024-11-27 07:45:42.718795526  [INFO] Starting NGINX...
2024-11-27 07:45:42.733145265  [INFO] No TLS certificate found. Generating a self signed certificate...
2024-11-27 07:45:42.733624377  [INFO] Starting Frigate...
2024-11-27 07:45:42.764135166  [INFO] Got IP address from supervisor: 10.101.111.36
2024-11-27 07:45:42.811346753  [INFO] Got WebRTC port from supervisor: 8555
2024-11-27 07:45:43.287389717  [INFO] Starting go2rtc...
2024-11-27 07:45:43.393445546  08:45:43.393 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2024-11-27 07:45:43.393451758  08:45:43.393 INF config path=/dev/shm/go2rtc.yaml
2024-11-27 07:45:43.394536376  08:45:43.394 INF [api] listen addr=:1984
2024-11-27 07:45:43.394539928  08:45:43.394 INF [rtsp] listen addr=:8554
2024-11-27 07:45:43.395089482  08:45:43.395 INF [webrtc] listen addr=:8555/tcp
2024-11-27 07:45:44.591588103  [2024-11-27 08:45:44] frigate.app                    INFO    : Starting Frigate (0.14.1-f4f3cfa)
2024-11-27 07:45:44.591804978  [2024-11-27 08:45:44] frigate.app                    INFO    : Creating directory: /tmp/cache
2024-11-27 07:45:44.599731712  [2024-11-27 08:45:44] frigate.util.config            INFO    : Checking if frigate config needs migration...
2024-11-27 07:45:44.672787420  [2024-11-27 08:45:44] frigate.util.config            INFO    : frigate config does not need migration...
2024-11-27 07:45:44.751631766  [2024-11-27 08:45:44] frigate.util.services          WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
s6-rc: info: service certsync successfully started
s6-rc: info: service legacy-services: starting
2024-11-27 07:45:45.667575544  [INFO] Starting certsync...
s6-rc: info: service legacy-services successfully started
2024-11-27 07:45:45.827086728  127.0.0.1 - - [27/Nov/2024:08:45:45 +0100] "" 400 0 "-" "-" "-"
2024-11-27 07:45:47.272340046  2024/11/27 08:45:47 [error] 199#199: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa:5000"
2024-11-27 07:45:47.272347065  2024/11/27 08:45:47 [error] 199#199: *2 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa:5000"
2024-11-27 07:45:47.665779060  2024/11/27 08:45:47 [error] 200#200: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2024-11-27 07:45:47.665826370  2024/11/27 08:45:47 [error] 200#200: *4 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2024-11-27 07:45:50.654678513  [2024-11-27 08:45:50] peewee_migrate.logs            INFO    : Starting migrations
2024-11-27 07:45:50.655953447  [2024-11-27 08:45:50] peewee_migrate.logs            INFO    : There is nothing to migrate
2024-11-27 07:45:50.669375629  [2024-11-27 08:45:50] frigate.app                    INFO    : Recording process started: 511
2024-11-27 07:45:50.669517433  [2024-11-27 08:45:50] frigate.app                    INFO    : Recording process started: 512
2024-11-27 07:45:50.675223264  [2024-11-27 08:45:50] frigate.app                    INFO    : go2rtc process pid: 98
2024-11-27 07:45:50.742276615  [2024-11-27 08:45:50] detector.coral                 INFO    : Starting detection process: 540
2024-11-27 07:45:50.748435924  Process detector:coral:
2024-11-27 07:45:50.749380144  [2024-11-27 08:45:50] frigate.detectors.plugins.edgetpu_tfl INFO    : Attempting to load TPU as usb
2024-11-27 07:45:50.749384049  [2024-11-27 08:45:50] frigate.detectors.plugins.edgetpu_tfl ERROR   : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2024-11-27 07:45:50.750465129  Traceback (most recent call last):
2024-11-27 07:45:50.750512143    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2024-11-27 07:45:50.750514804      delegate = Delegate(library, options)
2024-11-27 07:45:50.750516862    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2024-11-27 07:45:50.750518424      raise ValueError(capture.message)
2024-11-27 07:45:50.750559983  ValueError
2024-11-27 07:45:50.750562140
2024-11-27 07:45:50.750564032  During handling of the above exception, another exception occurred:
2024-11-27 07:45:50.750565465
2024-11-27 07:45:50.750567034  Traceback (most recent call last):
2024-11-27 07:45:50.750603791    File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2024-11-27 07:45:50.750681776      self.run()
2024-11-27 07:45:50.750683623    File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2024-11-27 07:45:50.750685183      self._target(*self._args, **self._kwargs)
2024-11-27 07:45:50.750686844    File "/opt/frigate/frigate/object_detection.py", line 102, in run_detector
2024-11-27 07:45:50.750688381      object_detector = LocalObjectDetector(detector_config=detector_config)
2024-11-27 07:45:50.750691716    File "/opt/frigate/frigate/object_detection.py", line 53, in __init__
2024-11-27 07:45:50.750720843      self.detect_api = create_detector(detector_config)
2024-11-27 07:45:50.750722940    File "/opt/frigate/frigate/detectors/__init__.py", line 18, in create_detector
2024-11-27 07:45:50.750724331      return api(detector_config)
2024-11-27 07:45:50.750772167    File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 41, in __init__
2024-11-27 07:45:50.750774387      edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2024-11-27 07:45:50.750776092    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2024-11-27 07:45:50.750777477      raise ValueError('Failed to load delegate from {}\n{}'.format(
2024-11-27 07:45:50.750778913  ValueError: Failed to load delegate from libedgetpu.so.1.0
2024-11-27 07:45:50.750780042
2024-11-27 07:45:50.755560638  [2024-11-27 08:45:50] frigate.app                    INFO    : Output process started: 542
2024-11-27 07:45:50.795540595  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor not started for disabled camera BK-Flur
2024-11-27 07:45:50.796439328  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor not started for disabled camera BK-WoZi
2024-11-27 07:45:50.822583862  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor started for BK-Terasse: 558
2024-11-27 07:45:50.842226389  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor started for SM-Hof-Nord: 563
2024-11-27 07:45:50.845372880  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor started for SM-Hof-West-Zelt: 570
2024-11-27 07:45:50.878886329  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor started for SM-Buero-OG: 577
2024-11-27 07:45:50.878892374  [2024-11-27 08:45:50] frigate.app                    INFO    : Camera processor started for BK-PhyLink: 585
2024-11-27 07:45:50.878894265  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process not started for disabled camera BK-Flur
2024-11-27 07:45:50.878895988  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process not started for disabled camera BK-WoZi
2024-11-27 07:45:50.899398924  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process started for BK-Terasse: 597
2024-11-27 07:45:50.915652176  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process started for SM-Hof-Nord: 602
2024-11-27 07:45:50.960389776  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process started for SM-Hof-West-Zelt: 607
2024-11-27 07:45:50.968999088  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process started for SM-Buero-OG: 618
2024-11-27 07:45:50.980626957  [2024-11-27 08:45:50] frigate.app                    INFO    : Capture process started for BK-PhyLink: 622
2024-11-27 07:45:52.717494619  [INFO] Starting go2rtc healthcheck service...
2024-11-27 07:46:11.048154685  [2024-11-27 08:46:11] ffmpeg.SM-Buero-OG.record      ERROR   : rtsp://127.0.0.1:8554/SM-Buero-OG: Invalid data found when processing input
2024-11-27 07:46:11.048159910  [2024-11-27 08:46:11] watchdog.SM-Buero-OG           INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:11.048188142  [2024-11-27 08:46:11] watchdog.SM-Buero-OG           INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:11.136918346  [2024-11-27 08:46:11] frigate.watchdog               INFO    : Detection appears to have stopped. Exiting Frigate...
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service go2rtc-healthcheck: stopping
s6-rc: info: service certsync: stopping
2024-11-27 07:46:11.150908711  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
s6-rc: info: service go2rtc-healthcheck successfully stopped
2024-11-27 07:46:11.153427758  [INFO] Service CERTSYNC exited with code 256 (by signal 15)
s6-rc: info: service certsync successfully stopped
s6-rc: info: service nginx: stopping
s6-rc: info: service certsync-log: stopping
s6-rc: info: service certsync-log successfully stopped
2024-11-27 07:46:11.210894821  [INFO] Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service nginx-log: stopping
s6-rc: info: service frigate: stopping
s6-rc: info: service nginx-log successfully stopped
2024-11-27 07:46:11.217336131  [2024-11-27 08:46:11] frigate.app                    INFO    : Flask has exited...
2024-11-27 07:46:11.217827295  [2024-11-27 08:46:11] frigate.app                    INFO    : Stopping...
2024-11-27 07:46:11.220833825  [2024-11-27 08:46:11] frigate.ptz.autotrack          INFO    : Exiting autotracker...
2024-11-27 07:46:11.221368345  [2024-11-27 08:46:11] frigate.storage                INFO    : Exiting storage maintainer...
2024-11-27 07:46:11.221934692  [2024-11-27 08:46:11] frigate.events.cleanup         INFO    : Exiting event cleanup...
2024-11-27 07:46:11.222238775  [2024-11-27 08:46:11] frigate.app                    INFO    : Waiting for capture process for BK-Terasse to stop
2024-11-27 07:46:11.222277814  [2024-11-27 08:46:11] frigate.watchdog               INFO    : Exiting watchdog...
2024-11-27 07:46:11.222686201  [2024-11-27 08:46:11] frigate.record.cleanup         INFO    : Exiting recording cleanup...
2024-11-27 07:46:11.222689373  [2024-11-27 08:46:11] watchdog.BK-Terasse            INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:11.223275475  [2024-11-27 08:46:11] frigate.stats.emitter          INFO    : Exiting stats emitter...
2024-11-27 07:46:11.223309445  [2024-11-27 08:46:11] watchdog.BK-Terasse            INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:11.234846319  [2024-11-27 08:46:11] watchdog.BK-Terasse            INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:11.234980536  [2024-11-27 08:46:11] watchdog.BK-Terasse            INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:11.358873755  [2024-11-27 08:46:11] frigate.app                    INFO    : Waiting for capture process for SM-Hof-Nord to stop
2024-11-27 07:46:11.361471153  [2024-11-27 08:46:11] watchdog.SM-Hof-Nord           INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:11.361790558  [2024-11-27 08:46:11] watchdog.SM-Hof-Nord           INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:11.417328166  [2024-11-27 08:46:11] frigate.object_processing      INFO    : Exiting object processor...
2024-11-27 07:46:11.446503088  [2024-11-27 08:46:11] watchdog.SM-Hof-Nord           INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:11.446659942  [2024-11-27 08:46:11] watchdog.SM-Hof-Nord           INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:12.176148823  [2024-11-27 08:46:12] frigate.events.maintainer      INFO    : Exiting event processor...
2024-11-27 07:46:12.532847184  [2024-11-27 08:46:12] frigate.app                    INFO    : Waiting for capture process for SM-Hof-West-Zelt to stop
2024-11-27 07:46:12.535248028  [2024-11-27 08:46:12] watchdog.SM-Hof-West-Zelt      INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:12.535577035  [2024-11-27 08:46:12] watchdog.SM-Hof-West-Zelt      INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:12.581575450  [2024-11-27 08:46:12] watchdog.SM-Hof-West-Zelt      INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:12.581646352  [2024-11-27 08:46:12] watchdog.SM-Hof-West-Zelt      INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:12.608927812  [2024-11-27 08:46:12] frigate.app                    INFO    : Waiting for capture process for SM-Buero-OG to stop
2024-11-27 07:46:12.610056079  [2024-11-27 08:46:12] watchdog.SM-Buero-OG           INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:12.610188165  [2024-11-27 08:46:12] watchdog.SM-Buero-OG           INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:12.627524327  [2024-11-27 08:46:12] watchdog.SM-Buero-OG           INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:12.628202238  [2024-11-27 08:46:12] watchdog.SM-Buero-OG           INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:12.641984397  [2024-11-27 08:46:12] frigate.app                    INFO    : Waiting for capture process for BK-PhyLink to stop
2024-11-27 07:46:12.643285519  [2024-11-27 08:46:12] watchdog.BK-PhyLink            INFO    : Terminating the existing ffmpeg process...
2024-11-27 07:46:12.643789964  [2024-11-27 08:46:12] watchdog.BK-PhyLink            INFO    : Waiting for ffmpeg to exit gracefully...
2024-11-27 07:46:12.715753748  [2024-11-27 08:46:12] frigate.app                    INFO    : Waiting for process for BK-Terasse to stop
2024-11-27 07:46:14.714583965  [2024-11-27 08:46:14] frigate.video                  INFO    : BK-Terasse: emptying frame queue
2024-11-27 07:46:14.714590022  [2024-11-27 08:46:14] frigate.video                  INFO    : BK-Terasse: exiting subprocess
2024-11-27 07:46:14.722845662  [2024-11-27 08:46:14] frigate.app                    INFO    : Closing frame queue for BK-Terasse
2024-11-27 07:46:15.223876260  [2024-11-27 08:46:15] frigate.app                    INFO    : Waiting for process for SM-Hof-Nord to stop
2024-11-27 07:46:15.935635173  [2024-11-27 08:46:15] frigate.video                  INFO    : SM-Hof-Nord: emptying frame queue
2024-11-27 07:46:15.936214667  [2024-11-27 08:46:15] frigate.video                  INFO    : SM-Hof-Nord: exiting subprocess
2024-11-27 07:46:15.943442105  [2024-11-27 08:46:15] frigate.app                    INFO    : Closing frame queue for SM-Hof-Nord
2024-11-27 07:46:16.445382789  [2024-11-27 08:46:16] frigate.app                    INFO    : Waiting for process for SM-Hof-West-Zelt to stop
2024-11-27 07:46:21.245089039  [2024-11-27 08:46:21] frigate.video                  INFO    : SM-Hof-West-Zelt: emptying frame queue
2024-11-27 07:46:21.245690710  [2024-11-27 08:46:21] frigate.video                  INFO    : SM-Hof-West-Zelt: exiting subprocess
2024-11-27 07:46:21.255021912  [2024-11-27 08:46:21] frigate.app                    INFO    : Closing frame queue for SM-Hof-West-Zelt
2024-11-27 07:46:21.756427980  [2024-11-27 08:46:21] frigate.app                    INFO    : Waiting for process for SM-Buero-OG to stop
2024-11-27 07:46:22.446137134  [2024-11-27 08:46:22] frigate.video                  INFO    : SM-Buero-OG: emptying frame queue
2024-11-27 07:46:22.446488100  [2024-11-27 08:46:22] frigate.video                  INFO    : SM-Buero-OG: exiting subprocess
2024-11-27 07:46:22.456228646  [2024-11-27 08:46:22] frigate.app                    INFO    : Closing frame queue for SM-Buero-OG
2024-11-27 07:46:22.957159663  [2024-11-27 08:46:22] frigate.app                    INFO    : Waiting for process for BK-PhyLink to stop
2024-11-27 07:46:26.767826347  [2024-11-27 08:46:26] frigate.video                  INFO    : BK-PhyLink: emptying frame queue
2024-11-27 07:46:26.767921423  [2024-11-27 08:46:26] frigate.video                  INFO    : BK-PhyLink: exiting subprocess
2024-11-27 07:46:26.777171477  [2024-11-27 08:46:26] frigate.app                    INFO    : Closing frame queue for BK-PhyLink
2024-11-27 07:46:27.783474282  [2024-11-27 08:46:27] frigate.app                    INFO    : Detection queue closed
2024-11-27 07:46:28.284865218  [2024-11-27 08:46:28] frigate.app                    INFO    : Detected frames queue closed
2024-11-27 07:46:28.788419160  [2024-11-27 08:46:28] frigate.app                    INFO    : Timeline queue closed
2024-11-27 07:46:30.365794429  [2024-11-27 08:46:30] frigate.output.output          INFO    : exiting output process...
2024-11-27 07:46:30.722534937  [2024-11-27 08:46:30] frigate.record.maintainer      INFO    : Exiting recording maintenance...
2024-11-27 07:46:31.466477266  [2024-11-27 08:46:31] frigate.review.maintainer      INFO    : Exiting review maintainer...
2024-11-27 07:46:31.802550785  [2024-11-27 08:46:31] frigate.comms.ws               INFO    : Exiting websocket client...
2024-11-27 07:46:32.745245832  [2024-11-27 08:46:32] peewee.sqliteq                 INFO    : writer received shutdown request, exiting.
2024-11-27 07:46:33.773494828  /usr/lib/python3.9/multiprocessing/resource_tracker.py:216: UserWarning: resource_tracker: There appear to be 23 leaked shared_memory objects to clean up at shutdown
2024-11-27 07:46:33.773499698    warnings.warn('resource_tracker: There appear to be %d '
2024-11-27 07:46:33.778123044  [INFO] Service Frigate exited with code 0 (by signal 0)
s6-rc: info: service frigate successfully stopped
s6-rc: info: service go2rtc: stopping
s6-rc: info: service frigate-log: stopping
2024-11-27 07:46:33.782089293  exit with signal: terminated
s6-rc: info: service frigate-log successfully stopped
2024-11-27 07:46:33.791109919  [INFO] The go2rtc service exited with code 0 (by signal 0)
s6-rc: info: service go2rtc successfully stopped
s6-rc: info: service go2rtc-log: stopping
s6-rc: info: service go2rtc-log successfully stopped
s6-rc: info: service log-prepare: stopping
s6-rc: info: service s6rc-fdholder: stopping
s6-rc: info: service log-prepare successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service s6rc-fdholder successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
ideas?
for me it looks like coral is missing, right?
thanks
Manne
This is not the frigate forum.
your right, but well its a HA addon. and here are plenty smart guys with probably similar problems and experiences… and i already have a user account, and asked other frigate questions and got good answers. might have something to do with piping the coral through the docker?
Did you find a fix? Mine started doing the same.
Since today I got the same issue?
  • Core2025.4.4
  • Supervisor2025.04.1
  • Operating System15.2
  • Frontend20250411.0 ⸱ legacy
Generic x86-64
Figate 15.0 … usening TPU PCi Coral.
Anyone can help to solve the Issue?
2025-05-04 17:34:32.555344231  [2025-05-04 19:34:32] frigate.detectors.plugins.edgetpu_tfl INFO    : Attempting to load TPU as pci
2025-05-04 17:34:32.556154833  [2025-05-04 19:34:32] frigate.detectors.plugins.edgetpu_tfl ERROR   : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2025-05-04 17:34:32.557511971  Process detector:coral:
2025-05-04 17:34:32.557516780  Traceback (most recent call last):
2025-05-04 17:34:32.557519582    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2025-05-04 17:34:32.557521758      delegate = Delegate(library, options)
2025-05-04 17:34:32.557528300    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2025-05-04 17:34:32.557545217      raise ValueError(capture.message)
2025-05-04 17:34:32.557547981  ValueError
2025-05-04 17:34:32.557549952
2025-05-04 17:34:32.557553260  During handling of the above exception, another exception occurred:
2025-05-04 17:34:32.557555341
2025-05-04 17:34:32.557557549  Traceback (most recent call last):
2025-05-04 17:34:32.557560217    File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2025-05-04 17:34:32.557588574      self.run()
2025-05-04 17:34:32.557591487    File "/opt/frigate/frigate/util/process.py", line 41, in run_wrapper
2025-05-04 17:34:32.557594142      return run(*args, **kwargs)
2025-05-04 17:34:32.557597142    File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2025-05-04 17:34:32.557630553      self._target(*self._args, **self._kwargs)
2025-05-04 17:34:32.557633383    File "/opt/frigate/frigate/object_detection.py", line 121, in run_detector
2025-05-04 17:34:32.557636915      object_detector = LocalObjectDetector(detector_config=detector_config)
2025-05-04 17:34:32.557640078    File "/opt/frigate/frigate/object_detection.py", line 68, in __init__
2025-05-04 17:34:32.557643128      self.detect_api = create_detector(detector_config)
2025-05-04 17:34:32.557646417    File "/opt/frigate/frigate/detectors/__init__.py", line 18, in create_detector
2025-05-04 17:34:32.557649047      return api(detector_config)
2025-05-04 17:34:32.557675057    File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 41, in __init__
2025-05-04 17:34:32.557678499      edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2025-05-04 17:34:32.557681805    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2025-05-04 17:34:32.557685037      raise ValueError('Failed to load delegate from {}\n{}'.format(
2025-05-04 17:34:32.557688007  ValueError: Failed to load delegate from libedgetpu.so.1.0
yes i found the problem. my brand new google coral did die, it was still there, but then it was not really there, for what ever reason. in the end, it was just there but did not perform work.
havent replaced it, caus i mostly spend the year in hospital beds. only thing i managed to do is get a refund from my seller… after a lot of sending screenshots back and forth.
for me it started intermidiately. someties it crashed, sometimes not. with leaning towars crashing more and more often as time whent by.
hope that helps…
what doesnt help thouhg is folks that repeat “This is not the frigate forum.” obviously we know that. however we all run it in HA and we are members of this forum and obviously the frigate maintainer is reading here too. so even if this isnt the frigate forum, we get solutions, no need to bug the frigate maintainer about most of that. thats why I did not add the maintainer with an @…
anyway thanks nick for all your work, it is highly apreciated, no need to post here that its not the frigate forum, we know that :slight_smile:
cheers and have fun
